Error when updating DNN 9.1.1 to Dnn 9.2.0
Hi everyone,
I've recently updated my website from DNN version 4.9.5 to 9.1.1.
However, after the 9.2.0 update, I encountered the following error:
Has anyone else faced a similar issue after upgrading to DNN 9.1.1? Any guidance on how to resolve this would be greatly appreciated.
Thanks in advance for your help!
2024-09-09 10:00:22,953 [LAPTOP-9AREVRB1][Thread:124][FATAL] DotNetNuke.Framework.PageBase - An error has occurred while loading page.
System.MissingMethodException: Method not found: 'System.String DotNetNuke.Entities.Portals.PortalSettings.get_Version()'.
   at APMENU.APMENU.AddJs()
   at APMENU.APMENU.Page_Load(Object sender, EventArgs e)
   at System.Web.UI.Control.OnLoad(EventArgs e)
2024-09-09 10:00:22,954 [LAPTOP-9AREVRB1][Thread:124][ERROR] DotNetNuke.Services.Exceptions.Exceptions - ~/Default.aspx?tabid=80&error=terminate
2024-09-09 10:00:22,971 [LAPTOP-9AREVRB1][Thread:124][ERROR] DotNetNuke.Services.Exceptions.Exceptions - DotNetNuke.Services.Exceptions.PageLoadException: Method not found: 'System.String DotNetNuke.Entities.Portals.PortalSettings.get_Version()'. ---> System.MissingMethodException: Method not found: 'System.String DotNetNuke.Entities.Portals.PortalSettings.get_Version()'.
Have a look at this..
https://www.dnnsoftware.c...enu-method-not-found
Before upgrading to/past DNN 9.2.0, you'll want to upgrade all extensions third-party extensions, and also recompile any custom extensions against DNN 9.2.0 and be ready to install those immediately after. The order also depends on your upgrade workflow. Every site upgrade is at least a bit different.
