Error while upgrading from 8.0.4 to 9.1.1
Hello,
We're trying to upgrade our instance from DNN 7.4.2 to DNN 9.8, so i'm following the Suggested Upgrade Path.
After doing a first update to DNN 8.0.4 without encountering any problems, I try to update to DNN 9.1.1. I then get this error during the process:
00:01:23.038 -   Installing Package File Dnn.PersonaBar.AdminLogs_02.00.01_Install:
Value cannot be null.
Parameter name: type
Exception Details: System.ArgumentNullException: Value cannot be null.
Source Error:
<code>An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.</code>
Stack Trace:
<code>
&#91;ArgumentNullException: Value cannot be null.
Parameter name: type&#93;
   System.Activator.CreateInstance(Type type, Boolean nonPublic) +12754527
   System.Activator.CreateInstance(Type type) +12
   DotNetNuke.Services.Installer.Installers.InstallerFactory.GetInstaller(String installerType) +1411
   DotNetNuke.Services.Installer.Installers.InstallerFactory.GetInstaller(XPathNavigator manifestNav, PackageInfo package) +55
   DotNetNuke.Services.Installer.Installers.PackageInstaller.ReadComponents(XPathNavigator manifestNav) +396
   DotNetNuke.Services.Installer.Installers.PackageInstaller.ReadManifest(XPathNavigator manifestNav) +3518
   DotNetNuke.Services.Installer.Installers.PackageInstaller..ctor(String packageManifest, InstallerInfo info) +229
   DotNetNuke.Services.Installer.Installer.ProcessPackages(XPathNavigator rootNav) +299
   DotNetNuke.Services.Installer.Installer.ReadManifest(Stream stream) +292
   DotNetNuke.Services.Installer.Installer.ReadManifest(Boolean deleteTemp) +86
   DotNetNuke.Services.Upgrade.Upgrade.InstallPackage(String file, String packageType, Boolean writeFeedback) +392
   DotNetNuke.Services.Install.Install.UpgradeApplication() +946
   DotNetNuke.Services.Install.Install.OnLoad(EventArgs e) +374
   System.Web.UI.Control.LoadRecursive() +61
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +693
</code>
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.8.4250.0
I tried to re-download the update package being careful that the file is not locked by Windows. I also tried removing this particular package, but then the following Dnn.PersonaBar module throws the same error. I also tried using the update package for DNN 9.2.2 and DNN 9.3.2 without any changes.
Thank you in advance for your time and your help
Nicolas
Can you check the log4net files, particularly Portals\_default\Logs\InstallerLogYYYYMMDD.resources. You can look at it with a text editor.
Hello,
Thanks for your response,
Here the logs of my last try (DNN 9.3.2).
11/23/2020 17:34:16 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpgradeDNN:09.03.02
11/23/2020 17:34:16 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpgradeVersion:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\08.00.04.01.SqlDataProvider
11/23/2020 17:34:16 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpgradeVersion:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.00.00.SqlDataProvider
11/23/2020 17:34:16 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start ExecuteScript:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.00.00.SqlDataProvider
11/23/2020 17:34:16 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End ExecuteScript:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.00.00.SqlDataProvider
11/23/2020 17:34:16 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpgradeVersion:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.00.00.01.SqlDataProvider
11/23/2020 17:34:16 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start ExecuteScript:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.00.00.01.SqlDataProvider
11/23/2020 17:34:17 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End ExecuteScript:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.00.00.01.SqlDataProvider
11/23/2020 17:34:17 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpgradeVersion:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.00.00.01.SqlDataProvider
11/23/2020 17:34:17 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpgradeVersion:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.00.01.SqlDataProvider
11/23/2020 17:34:17 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start ExecuteScript:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.00.01.SqlDataProvider
11/23/2020 17:34:17 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End ExecuteScript:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.00.01.SqlDataProvider
11/23/2020 17:34:17 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpgradeVersion:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.01.00.SqlDataProvider
11/23/2020 17:34:17 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start ExecuteScript:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.01.00.SqlDataProvider
11/23/2020 17:34:18 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End ExecuteScript:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.01.00.SqlDataProvider
11/23/2020 17:34:18 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpgradeVersion:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.01.00.SqlDataProvider
11/23/2020 17:34:18 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpgradeVersion:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.01.01.SqlDataProvider
11/23/2020 17:34:18 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start ExecuteScript:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.01.01.SqlDataProvider
11/23/2020 17:34:18 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End ExecuteScript:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.01.01.SqlDataProvider
11/23/2020 17:34:18 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpgradeVersion:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.02.00.SqlDataProvider
11/23/2020 17:34:18 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start ExecuteScript:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.02.00.SqlDataProvider
11/23/2020 17:34:19 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End ExecuteScript:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.02.00.SqlDataProvider
11/23/2020 17:34:19 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpgradeVersion:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.02.00.SqlDataProvider
11/23/2020 17:34:19 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpgradeVersion:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.02.01.SqlDataProvider
11/23/2020 17:34:19 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start ExecuteScript:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.02.01.SqlDataProvider
11/23/2020 17:34:19 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End ExecuteScript:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.02.01.SqlDataProvider
11/23/2020 17:34:19 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpgradeVersion:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.02.02.SqlDataProvider
11/23/2020 17:34:19 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start ExecuteScript:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.02.02.SqlDataProvider
11/23/2020 17:34:19 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End ExecuteScript:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.02.02.SqlDataProvider
11/23/2020 17:34:19 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpgradeVersion:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.03.00.SqlDataProvider
11/23/2020 17:34:19 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start ExecuteScript:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.03.00.SqlDataProvider
11/23/2020 17:34:19 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End ExecuteScript:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.03.00.SqlDataProvider
11/23/2020 17:34:19 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpgradeVersion:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.03.00.01.SqlDataProvider
11/23/2020 17:34:19 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start ExecuteScript:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.03.00.01.SqlDataProvider
11/23/2020 17:34:19 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End ExecuteScript:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.03.00.01.SqlDataProvider
11/23/2020 17:34:20 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpgradeVersion:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.03.00.01.SqlDataProvider
11/23/2020 17:34:20 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpgradeVersion:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.03.00.02.SqlDataProvider
11/23/2020 17:34:20 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start ExecuteScript:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.03.00.02.SqlDataProvider
11/23/2020 17:34:20 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End ExecuteScript:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.03.00.02.SqlDataProvider
11/23/2020 17:34:20 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpgradeVersion:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.03.01.SqlDataProvider
11/23/2020 17:34:20 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start ExecuteScript:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.03.01.SqlDataProvider
11/23/2020 17:34:20 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End ExecuteScript:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.03.01.SqlDataProvider
11/23/2020 17:34:20 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpgradeVersion:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.03.02.SqlDataProvider
11/23/2020 17:34:20 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start ExecuteScript:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.03.02.SqlDataProvider
11/23/2020 17:34:21 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End ExecuteScript:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.03.02.SqlDataProvider
11/23/2020 17:34:21 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpgradeVersion:C:\Developpement\Géosport\Geosport_dev\Website\Providers\DataProviders\SqlDataProvider\09.03.02.SqlDataProvider
11/23/2020 17:34:21 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start [L]Application Upgrades: 9.0.0
11/23/2020 17:34:21 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start [L]Application Upgrades: 9.0.1
11/23/2020 17:34:21 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start [L]Application Upgrades: 9.1.0
11/23/2020 17:34:21 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start RemoveHostPage:Host Settings
11/23/2020 17:34:21 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start RemoveHostPage:Site Management
11/23/2020 17:34:21 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start RemoveHostPage:Schedule
11/23/2020 17:34:21 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start RemoveHostPage:Superuser Accounts
11/23/2020 17:34:21 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start RemoveHostPage:Extensions
11/23/2020 17:34:21 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start RemoveHostPage:Device Detection Management
11/23/2020 17:34:22 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start RemoveAdminPages://Admin//Extensions
11/23/2020 17:34:22 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start RemoveAdminPages://Admin//SiteSettings
11/23/2020 17:34:23 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start RemoveAdminPages://Admin//SecurityRoles
11/23/2020 17:34:23 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start RemoveAdminPages://Admin//Taxonomy
11/23/2020 17:34:23 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start RemoveAdminPages://Admin//SiteRedirectionManagement
11/23/2020 17:34:24 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start RemoveAdminPages://Admin//DevicePreviewManagement
11/23/2020 17:34:24 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start RemoveAdminPages://Admin//SearchAdmin
11/23/2020 17:34:25 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:DotNetNuke.MobileManagement Type:Module Version:
11/23/2020 17:34:25 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:DotNetNuke.Modules.PreviewProfileManagement Type:Module Version:
11/23/2020 17:34:26 [INFO] DotNetNuke.Services.Installer.XmlMerge [L]Start RemoveNode:
11/23/2020 17:34:26 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:DotNetNuke.Dashboard.WebServer Type:DashboardControl Version:
11/23/2020 17:34:26 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:DotNetNuke.Dashboard.Database Type:DashboardControl Version:
11/23/2020 17:34:26 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:DotNetNuke.Dashboard.Host Type:DashboardControl Version:
11/23/2020 17:34:26 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:DotNetNuke.Dashboard.Portals Type:DashboardControl Version:
11/23/2020 17:34:26 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:DotNetNuke.Dashboard.Modules Type:DashboardControl Version:
11/23/2020 17:34:26 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:DotNetNuke.Dashboard.Skins Type:DashboardControl Version:
11/23/2020 17:34:26 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:DotNetNuke.HostSettings Type:Module Version:
11/23/2020 17:34:26 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:DotNetNuke.Languages Type:Module Version:
11/23/2020 17:34:30 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:DotNetNuke.Lists Type:Module Version:
11/23/2020 17:34:31 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start RemoveHostPage:Lists
11/23/2020 17:34:31 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:DotNetNuke.LogViewer Type:Module Version:
11/23/2020 17:34:32 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:DotNetNuke.RecycleBin Type:Module Version:
11/23/2020 17:34:32 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:DotNetNuke.Sitemap Type:Module Version:
11/23/2020 17:34:33 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:DotNetNuke.SiteWizard Type:Module Version:
11/23/2020 17:34:33 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:Dnn.Themes Type:Module Version:
11/23/2020 17:34:34 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:DotNetNuke.Tabs Type:Module Version:
11/23/2020 17:34:35 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:DotNetNuke.Portals Type:Module Version:
11/23/2020 17:34:35 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:DotNetNuke.Scheduler Type:Module Version:
11/23/2020 17:34:35 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:DotNetNuke.SearchAdmin Type:Module Version:
11/23/2020 17:34:35 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:DotNetNuke.SQL Type:Module Version:
11/23/2020 17:34:36 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start RemoveHostPage:SQL
11/23/2020 17:34:36 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:DotNetNuke.Extensions Type:Module Version:
11/23/2020 17:34:36 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:DotNetNuke.Configuration Manager Type:Module Version:
11/23/2020 17:34:36 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start RemoveHostPage:Configuration Manager
11/23/2020 17:34:36 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:DotNetNuke.Dashboard Type:Module Version:
11/23/2020 17:34:36 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start RemoveHostPage:Dashboard
11/23/2020 17:34:36 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:DotNetNuke.Google Analytics Type:Module Version:
11/23/2020 17:34:37 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:DotNetNuke.Taxonomy Type:Module Version:
11/23/2020 17:34:37 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:UrlManagement Type:Library Version:
11/23/2020 17:34:37 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start [L]Application Upgrades: 9.1.1
11/23/2020 17:34:37 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start [L]Application Upgrades: 9.2.0
11/23/2020 17:34:37 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start RemoveAdminPages://Admin//SearchEngineSiteMap
11/23/2020 17:34:37 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start RemoveAdminPages://Admin//Solutions
11/23/2020 17:34:37 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start RemoveAdminPages://Admin//BulkEmail
11/23/2020 17:34:38 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start RemoveHostPage:Marketplace
11/23/2020 17:34:38 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start RemoveHostPage:Module Definitions
11/23/2020 17:34:38 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start RemoveHostPage:Portals
11/23/2020 17:34:38 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start AddHostPage:Superuser Accounts
11/23/2020 17:34:38 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start AddPage:Superuser Accounts
11/23/2020 17:34:38 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start AddModuleToPage:15
11/23/2020 17:34:38 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End AddModuleToPage:15
11/23/2020 17:34:38 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start [L]Application Upgrades: 9.2.1
11/23/2020 17:34:38 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:jQuery Type:Javascript_Library Version:1.9.1
11/23/2020 17:34:38 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:jQuery-UI Type:Javascript_Library Version:1.11.3
11/23/2020 17:34:38 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start Uninstallation of Package:jQuery-Migrate Type:Javascript_Library Version:1.2.1
11/23/2020 17:34:38 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start [L]Application Upgrades: 9.2.2
11/23/2020 17:34:38 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start [L]Application Upgrades: 9.3.0
11/23/2020 17:34:39 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start [L]Application Upgrades: 9.3.0
11/23/2020 17:34:39 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start [L]Application Upgrades: 9.3.1
11/23/2020 17:34:39 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start [L]Application Upgrades: 9.3.2
11/23/2020 17:34:39 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start DeleteFiles:09.00.00
11/23/2020 17:34:39 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start DeleteFiles:09.00.00.01
11/23/2020 17:34:39 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start DeleteFiles:09.00.01
11/23/2020 17:34:39 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start DeleteFiles:09.01.00
11/23/2020 17:34:39 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start DeleteFiles:09.01.01
11/23/2020 17:34:39 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start DeleteFiles:09.02.00
11/23/2020 17:34:39 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start DeleteFiles:09.02.01
11/23/2020 17:34:39 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start DeleteFiles:09.02.02
11/23/2020 17:34:39 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start DeleteFiles:09.03.00
11/23/2020 17:34:39 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start DeleteFiles:09.03.00.01
11/23/2020 17:34:39 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start DeleteFiles:09.03.00.02
11/23/2020 17:34:39 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start DeleteFiles:09.03.01
11/23/2020 17:34:39 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start DeleteFiles:09.03.02
11/23/2020 17:34:39 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpdateConfig:09.00.00
11/23/2020 17:34:39 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpdateConfig:9.0.0
11/23/2020 17:34:39 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End UpdateConfig:9.0.0
11/23/2020 17:34:39 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End UpdateConfig:09.00.00
11/23/2020 17:34:39 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpdateConfig:09.00.00.01
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End UpdateConfig:9.0.0
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End UpdateConfig:09.00.00.01
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpdateConfig:09.00.01
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpdateConfig:9.0.1
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Installer.XmlMerge [L]Start RemoveNode:
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Installer.XmlMerge [L]Start UpdateNode: keyAttribute=
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End UpdateConfig:9.0.1
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End UpdateConfig:09.00.01
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpdateConfig:09.01.00
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpdateConfig:9.1.0
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End UpdateConfig:9.1.0
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End UpdateConfig:09.01.00
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpdateConfig:09.01.01
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpdateConfig:9.1.1
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Installer.XmlMerge [L]Start UpdateNode: keyAttribute=name
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End UpdateConfig:9.1.1
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End UpdateConfig:09.01.01
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpdateConfig:09.02.00
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpdateConfig:9.2.0
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End UpdateConfig:9.2.0
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End UpdateConfig:09.02.00
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpdateConfig:09.02.01
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpdateConfig:9.2.1
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End UpdateConfig:9.2.1
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End UpdateConfig:09.02.01
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpdateConfig:09.02.02
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpdateConfig:9.2.2
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End UpdateConfig:9.2.2
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End UpdateConfig:09.02.02
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpdateConfig:09.03.00
11/23/2020 17:34:40 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpdateConfig:9.3.0
11/23/2020 17:34:41 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End UpdateConfig:9.3.0
11/23/2020 17:34:41 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End UpdateConfig:09.03.00
11/23/2020 17:34:41 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpdateConfig:09.03.00.01
11/23/2020 17:34:41 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpdateConfig:9.3.0
11/23/2020 17:34:41 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End UpdateConfig:09.03.00.01
11/23/2020 17:34:41 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpdateConfig:09.03.00.02
11/23/2020 17:34:41 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End UpdateConfig:09.03.00.02
11/23/2020 17:34:41 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpdateConfig:09.03.01
11/23/2020 17:34:41 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpdateConfig:9.3.1
11/23/2020 17:34:41 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End UpdateConfig:9.3.1
11/23/2020 17:34:41 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End UpdateConfig:09.03.01
11/23/2020 17:34:41 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpdateConfig:09.03.02
11/23/2020 17:34:41 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start UpdateConfig:9.3.2
11/23/2020 17:34:41 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End UpdateConfig:9.3.2
11/23/2020 17:34:41 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]End UpdateConfig:09.03.02
11/23/2020 17:34:41 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Performing General Upgrades
11/23/2020 17:34:42 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\Module\DDRMenu_09.03.02_Install.zip
11/23/2020 17:34:43 [INFO] DotNetNuke.Services.Installer.XmlMerge [L]Start UpdateNode: keyAttribute=name
11/23/2020 17:34:44 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\Module\Dnn.EditBar.UI_02.00.01_Install.zip
11/23/2020 17:34:44 [INFO] DotNetNuke.Services.Installer.XmlMerge [L]Start UpdateNode: keyAttribute=name
11/23/2020 17:34:46 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\Module\Dnn.PersonaBar.UI_02.00.01_Install.zip
11/23/2020 17:34:49 [INFO] DotNetNuke.Services.Installer.XmlMerge [L]Start AddNode:
11/23/2020 17:34:49 [INFO] DotNetNuke.Services.Installer.XmlMerge [L]Start UpdateNode: keyAttribute=name
11/23/2020 17:34:49 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\Module\DNNCE_01_Web.Deprecated_09.03.02_Install.zip
11/23/2020 17:34:50 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\Module\DNNCE_AzureConnector_09.03.02_Install.zip
11/23/2020 17:34:50 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\Module\DNNCE_Console_09.03.02_Install.zip
11/23/2020 17:34:51 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\Module\DNNCE_CoreMessaging_09.03.02_Install.zip
11/23/2020 17:34:53 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\Module\DNNCE_DigitalAssetsManagement_09.03.02_Install.zip
11/23/2020 17:34:55 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\Module\DNNCE_HTML_09.03.02_Install.zip
11/23/2020 17:34:56 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\Module\DNNCE_HtmlEditorManager_09.03.02_Install.zip
11/23/2020 17:34:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\Module\DNNCE_Journal_09.03.02_Install.zip
11/23/2020 17:34:58 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\Module\DNNCE_MemberDirectory_09.03.02_Install.zip
11/23/2020 17:35:00 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\Module\DNNCE_ModuleCreator_09.03.02_Install.zip
11/23/2020 17:35:02 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\Module\DNNCE_RazorHost_09.03.02_Install.zip
11/23/2020 17:35:03 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\Module\DNNCE_SiteExportImport_09.03.02_Install.zip
11/23/2020 17:35:04 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\Module\DNNCE_SocialGroups_09.03.02_Install.zip
11/23/2020 17:35:06 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\Module\DNNCE_Website.Deprecated_09.03.02_Install.zip
11/23/2020 17:35:06 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\Module\GoogleAnalyticsConnector_09.03.02_Install.zip
11/23/2020 17:35:06 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\Module\Newtonsoft.Json_10.00.03_Install.zip
11/23/2020 17:35:07 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\Module\Telerik_09.02.01_Install.zip
11/23/2020 17:35:09 [INFO] DotNetNuke.Services.Installer.XmlMerge [L]Start UpdateNode: keyAttribute=path
11/23/2020 17:35:09 [INFO] DotNetNuke.Services.Installer.XmlMerge [L]Start UpdateNode: keyAttribute=name
11/23/2020 17:35:09 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\Skin\Skin_Xcillion_01.00.00_Install.zip
11/23/2020 17:35:11 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\JavaScriptLibrary\jQuery.zip
11/23/2020 17:35:11 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\JavaScriptLibrary\Selectize.zip
11/23/2020 17:35:11 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\Provider\AspNetClientCapabilityProvider_09.03.02_Install.zip
11/23/2020 17:35:12 [INFO] DotNetNuke.Services.Installer.XmlMerge [L]Start UpdateNode: keyAttribute=name
11/23/2020 17:35:12 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\Provider\DNNCE_FolderProviders_09.03.02_Install.zip
11/23/2020 17:35:13 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\Provider\DNNConnect.CKEditorProvider_01.00.05_Install.zip
11/23/2020 17:35:38 [INFO] DotNetNuke.Services.Installer.XmlMerge [L]Start UpdateNode: keyAttribute=name
11/23/2020 17:35:39 [INFO] DotNetNuke.Services.Upgrade.Upgrade [L]Start InstallPackage:C:\Developpement\Géosport\Geosport_dev\Website\Install\Module\Dnn.PersonaBar.AdminLogs_02.00.01_Install.zip
So, no error reported, right?
Given this situation, I would revert back to 8.0.4, and redo the upgrade. That includes downloading a fresh copy of the upgrade package, unblocking it, and copying the upgrade files to the installation's root directory.
Do you have an custom modifications to the database? Are you possibly using Turbo Scripts?
I actually had no execution error in the logs.
However, I found the problem, I had add key="ShowMissingKeys" value="true" in my web.config , which caused a problem when executing line 121 of DotNetNuke.Services.Install.Installers.InstallFactory.cs
because entry.Text was equal to "RESX:PersonaBarMenu.Text".
I just remove it in web.config and the upgrade work without errors.
Thanks for your time
Nicolas
