Friendly URLs Not Working in 8.0.4
Hi
I am trying to upgrade a website from 6.2.9 to 9.7.*
I have upgraded to 7.0.0 and then to 7.4.2 fine and the website works just as it did.
I had all sorts of issues trying to upgrade to 8.0.4 with lots of error including:
Could not load type DotNetNuke.HttpModules.Config.RewriterRule Collection' from assembly 'DotNetNuke.HttpModules, Version=8.0.4.226, Culture=neutral, PublicKeyToken=null.
So in version 7.4.2 I removed TanLD rewriter completely and got the site working without friendly URLs, just tabids. I then upgraded to 8.0.4 and the site still works just as it did in 7.4.2, without friendly rewriting and with tabids in the URLs.
Now though if I try to enable Use Friendly URLs I get the following:
  • Website pages display fine without the tabids in the URL but with the file name extension in capitals as the page names are.
  • Admin pages display, again with the file name extension, e.g. .../Admin/Pages.aspx.
  • Host pages give 404, URL e.g. .../Host/FileManagement/tabid/122/portalid/0/  looking for file: \Host\FileManagement\tabid\122\portalid\0\
I've been trying to go through the web.config in detail, comparing it to what a clean install of 8.0.4 would have installed and there are many differences, but I'm not exactly sure what I'm looking for. The rewriting sections are the same though.
Any help would be much appreciated.
Set the URL type to "advanced" in web.config.
Thanks so much Joe, that works a treat.
Just one more query of that's OK. Do I need to install an Extension URL Provider to force the friendly URLs to lowercase? Or, is there a tweak to the DNNFriendlyUrl web.config entry that will do the trick?
Many thanks again.
I have since upgraded to 9.1.1 and the option to force to lowercase is now in there.
