Upgrading DNN to 9.7.2
Hi everybody,
I am trying to upgrade from 7.3.3 to 9.7.2, and in order to achieve that i have started with the first step: upgrading to 7.4.2. After the installation ended, the only error apeared in the final install report was this: "Installing Package File Telerik_07.03.04_Install: Error!"
What should I do next?
Thank you,
I would take a look at the log4net files, particularly the install file, to see if there are more details about the failure.
Thank you for the answer.
Unfortunetaly, there is no file in /logs folder. There are two folders (Web and WS) empty.
/Portals/_default/Logs ?
There should be files named yyyy.mm.dd.log.resources and InstallerLogyyyymmdd.resources, and a directory named LogConfig.
Nothing usefull is there. I've found 2 files: 2020.10.29.log.resources and InstallerLog20201029.resources but has no error inside.
OK, that's odd.
Did the upgrade run to completion? What happened if you browsed to the site?
So, what I would do is:
1. Revert to the 7.3.3 version.
2. Copy the Upgrade package after verifying that the package has been unblocked.
3. Start the upgrade.
I've already do this:
Yes, the upgrade process has rich the end.
The site seems to work but i still have some problems on some pages, and when i look into log i am finding many of :
2020-10-29 19:48:27,070 [xxx][Thread:22][ERROR] DotNetNuke.Services.Exceptions.Exceptions - System.MissingMethodException: Cannot create an abstract class.
   at System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
   at System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
   at System.Activator.CreateInstance(Type type, Boolean nonPublic)
   at System.Activator.CreateInstance(Type type)
   at DotNetNuke.UI.Skins.Pane.IsVesionableModule(ModuleInfo moduleInfo)
   at DotNetNuke.UI.Skins.Pane.InjectModule(ModuleInfo module)
   at DotNetNuke.UI.Skins.Skin.InjectModule(Pane pane, ModuleInfo module)
Do those pages have a specific module placed on them?
