Issue After Upgrading to DNN 10 – Site Not Loading Properly / Errors Occurring
Hi Community,
I'm encountering issues after upgrading my DNN site to version 10.0.0. Here's a breakdown of my current setup and the problems I'm facing:
Upgrade Details:
  • Previous DNN Version: v09.13.09
  • Current DNN Version: 10.0.0
  • Upgrade Method: Downloaded the upgrade ZIP and followed the same steps as in previous upgrades.
After the upgrade, the site either doesn't load or throws errors. It also didn't show the upgrade window.
Has anyone else faced similar issues after upgrading to DNN 10?
Are there known compatibility concerns or additional steps I should take post-upgrade?
Any guidance would be greatly appreciated.
Yes, the upgrade to DNN10.0.0 was impossible for us because of localization issues. There is DNN10.0.1 out now. We've not yet had time to test that.
Try v10.0.1 and and see if it fixes your issue. If not you can report an issue on GitHub.
@david Lee
I have done the exact steps as Shivam except the face I am upgrading from 9.13.9 to 10.0.1
I ended up having this error
[code]
~mysite/Default.aspx?tabid=21&error=Method+not+found%3a+%27Void+DotNetNuke.Framework.jQuery.RequestRegistration()%27.&content=0
[/code]
Hi, I solved the issue. Error is related to some componente inside Skin.
Try changing first line of your skin files asxc to this
<%@ Control Language="C#" AutoEventWireup="true" Inherits="DotNetNuke.UI.Skins.Skin" %>
After this site was loaded
