Upgrade issue going from 9.13.9 to 10.0.0
Hello,
I have attempted to upgrade a fresh install of 9.13.9 (no issues during the installation) to 10.0.0 twice now and I continue to receive the following error during the upgrade process;
21% ERROR occured - System.Data.SqlClient.SqlException (0x80131904): Incorrect syntax near the keyword 'IF'. at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) at System.Data.SqlClient.SqlCommand.RunExecuteNonQueryTds(String methodName, Boolean async, Int32 timeout, Boolean asyncWrite) at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry) at System.Data.SqlClient.SqlCommand.ExecuteNonQuery() at DotNetNuke.Data.SqlDatabaseConnectionProvider.ExecuteNonQuery(String connectionString, CommandType commandType, Int32 commandTimeout, String query) at DotNetNuke.Data.SqlDataProvider.ExecuteScriptInternal(String connectionString, String script, Int32 timeoutSec) ClientConnectionId:9bb5416e-fdee-462e-adae-99df0486216d Error Number:156,State:1,Class:15 DROP VIEW IF EXISTS dbo.[vw_ApiTokens]
Tim
DROP VIEW IF EXISTS {databaseOwner}[{objectQualifier}vw_ApiTokens]
is in the 10.00.00.SqlDataProvider. And is a valid statement. However, this format of DROP VIEW is only valid from SQL 2016 and above. What version of SQL do you have?
I have created an issue in GitHub for this.
https://github.com/dnnsof...Platform/issues/6547
I decided to do the pull request to fix this issue.
Sorry about all the comments!!
If you want to fix this problem you can edit the 10.00.00.SqlDataProvider file in the upgrade package before you run it. See the issue for the required SQL command.
As for the installations already upgraded, check for the "vw_ApiTokens" view in the database. If it's there I think it will be OK. If not you can try running the rest of the SQL command required. lines: 425 to the end. Although in this situation I would opt for a restore of the installation, a SQL upgrade and redo the upgrade of the DNN installation. If you cannot upgrade SQL, restore the DNN installation, change the SQL command in the upgrade package and redo the upgrade.
Sorry for the late response David. I'm using SQL Express 2012. I may upgrade SQL if need be. I'll try your suggestions first though.
I upgraded from SQL Express 2012 to 2019 and that solved the issue. I was able to upgrade to 10.0.0 with no issue.
Nice catch guys! Thanks shph_itmanager for sharing the solution.
