Issue Upgrading From 9.01 to 9.03
Hello, I've been upgrading an older DNN sitte for a client that started out on version 8.04 and I've been following the suggested upgrade path to get the site current. I was able to upgrade from 8.04 to 9.01 without issue. However upon upgrading to 9.03 I began receiving an internal server error when attempting to load the site. As far as I can tell from the upgrade log file in \Portals\_default\Logs\ the upgrade appears to have completed without issue. The error being throws is System.MissingMethodException from DotNetNuke.Web.Common.Internal.DotNetNukeHttpApplication the message being Method not found: 'System.String DotNetNuke.Entities.Modules.ModuleController.CacheKey(Int32)'.
I'm not sure if perhaps the upgrade partially failed and some un-upgraded dlls are trying to access deprecated methods from successfully upgrade portions of the code or if there's a problematic module calling a method that was deprecated in 9.03.
Please find the message/stack trace in its entirety below:
2021-06-14 04:56:02,420 [pd0sdwk00002D][Thread:42][FATAL] DotNetNuke.Web.Common.Internal.DotNetNukeHttpApplication - System.MissingMethodException: Method not found: 'System.String DotNetNuke.Entities.Modules.ModuleController.CacheKey(Int32)'.
   at DotNetNuke.Modules.Links.Links.Page_Unload(Object sender, EventArgs e)
   at System.Web.UI.Control.OnUnload(EventArgs e)
   at System.Web.UI.Control.UnloadRecursive(Boolean dispose)
   at System.Web.UI.Page.UnloadRecursive(Boolean dispose)
   at System.Web.UI.Page.ProcessRequestCleanup()
   at System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
   at System.Web.UI.Page.ProcessRequest()
   at System.Web.UI.Page.ProcessRequest(HttpContext context)
   at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
   at System.Web.HttpApplication.<>c__DisplayClass285_0.b__0()
2021-06-14 04:56:04,905 [pd0sdwk00002D][Thread:26][ERROR] DotNetNuke.Services.Exceptions.Exceptions - System.OutOfMemoryException: Array dimensions exceeded supported range.
   at Lucene.Net.Index.SegmentInfo..ctor(Directory dir, Int32 format, IndexInput input)
   at Lucene.Net.Index.SegmentInfos.Read(Directory directory, String segmentFileName)
   at Lucene.Net.Index.SegmentInfos.AnonymousClassFindSegmentsFile.DoBody(String segmentFileName)
   at Lucene.Net.Index.SegmentInfos.FindSegmentsFile.Run(IndexCommit commit)
   at Lucene.Net.Index.SegmentInfos.Read(Directory directory)
   at Lucene.Net.Index.IndexWriter.Init(Directory d, Analyzer a, Boolean create, IndexDeletionPolicy deletionPolicy, Int32 maxFieldLength, IndexingChain indexingChain, IndexCommit commit)
   at Lucene.Net.Index.IndexWriter..ctor(Directory d, Analyzer a, MaxFieldLength mfl)
   at DotNetNuke.Services.Search.Internals.LuceneControllerImpl.get_Writer()
   at DotNetNuke.Services.Search.Internals.LuceneControllerImpl.Delete(Query query)
   at DotNetNuke.Services.Search.Internals.InternalSearchControllerImpl.DeleteSearchDocumentInternal(SearchDocument searchDocument, Boolean autoCommit)
   at DotNetNuke.Services.Search.SearchEngine.DeleteRemovedObjects()
   at DotNetNuke.Services.Search.SearchEngineScheduler.DoWork()
Here is the upgrade log:
06/14/2021 03:44:46 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\Newtonsoft.Json_10.00.03_Install.zip
06/14/2021 03:45:48 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start UpgradeDNN:09.03.02
06/14/2021 03:45:48 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start UpgradeVersion:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.02.00.SqlDataProvider
06/14/2021 03:45:48 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start ExecuteScript:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.02.00.SqlDataProvider
06/14/2021 03:45:50 [INFO] DotNetNuke.Services.Upgrade.Upgrade End ExecuteScript:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.02.00.SqlDataProvider
06/14/2021 03:45:50 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start UpgradeVersion:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.02.00.SqlDataProvider
06/14/2021 03:45:50 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start UpgradeVersion:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.02.01.SqlDataProvider
06/14/2021 03:45:50 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start ExecuteScript:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.02.01.SqlDataProvider
06/14/2021 03:45:51 [INFO] DotNetNuke.Services.Upgrade.Upgrade End ExecuteScript:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.02.01.SqlDataProvider
06/14/2021 03:45:51 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start UpgradeVersion:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.02.01.SqlDataProvider
06/14/2021 03:45:51 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start UpgradeVersion:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.02.02.SqlDataProvider
06/14/2021 03:45:51 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start ExecuteScript:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.02.02.SqlDataProvider
06/14/2021 03:45:51 [INFO] DotNetNuke.Services.Upgrade.Upgrade End ExecuteScript:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.02.02.SqlDataProvider
06/14/2021 03:45:51 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start UpgradeVersion:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.03.00.SqlDataProvider
06/14/2021 03:45:51 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start ExecuteScript:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.03.00.SqlDataProvider
06/14/2021 03:45:51 [INFO] DotNetNuke.Services.Upgrade.Upgrade End ExecuteScript:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.03.00.SqlDataProvider
06/14/2021 03:45:51 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start UpgradeVersion:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.03.00.01.SqlDataProvider
06/14/2021 03:45:51 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start ExecuteScript:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.03.00.01.SqlDataProvider
06/14/2021 03:45:51 [INFO] DotNetNuke.Services.Upgrade.Upgrade End ExecuteScript:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.03.00.01.SqlDataProvider
06/14/2021 03:45:52 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start UpgradeVersion:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.03.00.01.SqlDataProvider
06/14/2021 03:45:52 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start UpgradeVersion:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.03.00.02.SqlDataProvider
06/14/2021 03:45:52 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start ExecuteScript:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.03.00.02.SqlDataProvider
06/14/2021 03:45:52 [INFO] DotNetNuke.Services.Upgrade.Upgrade End ExecuteScript:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.03.00.02.SqlDataProvider
06/14/2021 03:45:52 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start UpgradeVersion:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.03.01.SqlDataProvider
06/14/2021 03:45:52 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start ExecuteScript:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.03.01.SqlDataProvider
06/14/2021 03:45:52 [INFO] DotNetNuke.Services.Upgrade.Upgrade End ExecuteScript:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.03.01.SqlDataProvider
06/14/2021 03:45:52 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start UpgradeVersion:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.03.02.SqlDataProvider
06/14/2021 03:45:52 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start ExecuteScript:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.03.02.SqlDataProvider
06/14/2021 03:45:52 [INFO] DotNetNuke.Services.Upgrade.Upgrade End ExecuteScript:C:\home\site\wwwroot\Providers\DataProviders\SqlDataProvider\09.03.02.SqlDataProvider
06/14/2021 03:45:52 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start Application Upgrades: 9.2.0
06/14/2021 03:45:52 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start RemoveAdminPages://Admin//SearchEngineSiteMap
06/14/2021 03:45:52 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start RemoveAdminPages://Admin//Solutions
06/14/2021 03:45:54 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start RemoveAdminPages://Admin//BulkEmail
06/14/2021 03:45:54 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start RemoveHostPage:Marketplace
06/14/2021 03:45:54 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start RemoveHostPage:Module Definitions
06/14/2021 03:45:54 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start RemoveHostPage:Portals
06/14/2021 03:45:54 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start AddHostPage:Superuser Accounts
06/14/2021 03:45:54 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start AddPage:Superuser Accounts
06/14/2021 03:45:55 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start AddModuleToPage:15
06/14/2021 03:45:55 [INFO] DotNetNuke.Services.Upgrade.Upgrade End AddModuleToPage:15
06/14/2021 03:45:55 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start Application Upgrades: 9.2.1
06/14/2021 03:45:55 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start Uninstallation of Package:jQuery Type:Javascript_Library Version:1.9.1
06/14/2021 03:45:56 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start Uninstallation of Package:jQuery-UI Type:Javascript_Library Version:1.11.3
06/14/2021 03:45:56 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start Uninstallation of Package:jQuery-Migrate Type:Javascript_Library Version:1.2.1
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start Application Upgrades: 9.2.2
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start Application Upgrades: 9.3.0
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start Application Upgrades: 9.3.1
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start Application Upgrades: 9.3.2
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start DeleteFiles:09.02.00
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start DeleteFiles:09.02.01
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start DeleteFiles:09.02.02
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start DeleteFiles:09.03.00
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start DeleteFiles:09.03.00.01
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start DeleteFiles:09.03.00.02
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start DeleteFiles:09.03.01
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start DeleteFiles:09.03.02
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start UpdateConfig:09.02.00
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start UpdateConfig:9.2.0
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Installer.XmlMerge Start RemoveNode:
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade End UpdateConfig:9.2.0
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade End UpdateConfig:09.02.00
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start UpdateConfig:09.02.01
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start UpdateConfig:9.2.1
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade End UpdateConfig:9.2.1
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade End UpdateConfig:09.02.01
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start UpdateConfig:09.02.02
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start UpdateConfig:9.2.2
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade End UpdateConfig:9.2.2
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade End UpdateConfig:09.02.02
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start UpdateConfig:09.03.00
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start UpdateConfig:9.3.0
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Installer.XmlMerge Start UpdateNode: keyAttribute=name
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade End UpdateConfig:9.3.0
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade End UpdateConfig:09.03.00
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start UpdateConfig:09.03.00.01
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade End UpdateConfig:09.03.00.01
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start UpdateConfig:09.03.00.02
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade End UpdateConfig:09.03.00.02
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start UpdateConfig:09.03.01
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start UpdateConfig:9.3.1
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade End UpdateConfig:9.3.1
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade End UpdateConfig:09.03.01
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start UpdateConfig:09.03.02
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start UpdateConfig:9.3.2
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade End UpdateConfig:9.3.2
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade End UpdateConfig:09.03.02
06/14/2021 03:45:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Performing General Upgrades
06/14/2021 03:46:02 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\DDRMenu_09.03.02_Install.zip
06/14/2021 03:46:05 [INFO] DotNetNuke.Services.Installer.XmlMerge Start UpdateNode: keyAttribute=name
06/14/2021 03:46:06 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\Dnn.EditBar.UI_02.00.01_Install.zip
06/14/2021 03:46:07 [INFO] DotNetNuke.Services.Installer.XmlMerge Start RemoveNode:
06/14/2021 03:46:07 [INFO] DotNetNuke.Services.Installer.XmlMerge Start UpdateNode: keyAttribute=name
06/14/2021 03:46:13 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\Dnn.PersonaBar.UI_02.00.01_Install.zip
06/14/2021 03:46:18 [INFO] DotNetNuke.Services.Installer.XmlMerge Start RemoveNode:
06/14/2021 03:46:18 [INFO] DotNetNuke.Services.Installer.XmlMerge Start AddNode:
06/14/2021 03:46:18 [INFO] DotNetNuke.Services.Installer.XmlMerge Start UpdateNode: keyAttribute=name
06/14/2021 03:46:20 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\DNNCE_01_Web.Deprecated_09.03.02_Install.zip
06/14/2021 03:46:20 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\DNNCE_AzureConnector_09.03.02_Install.zip
06/14/2021 03:46:21 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\DNNCE_Console_09.03.02_Install.zip
06/14/2021 03:46:22 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\DNNCE_CoreMessaging_09.03.02_Install.zip
06/14/2021 03:46:24 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\DNNCE_DigitalAssetsManagement_09.03.02_Install.zip
06/14/2021 03:46:28 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\DNNCE_HTML_09.03.02_Install.zip
06/14/2021 03:46:31 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\DNNCE_HtmlEditorManager_09.03.02_Install.zip
06/14/2021 03:46:32 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\DNNCE_Journal_09.03.02_Install.zip
06/14/2021 03:46:34 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\DNNCE_MemberDirectory_09.03.02_Install.zip
06/14/2021 03:46:37 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\DNNCE_ModuleCreator_09.03.02_Install.zip
06/14/2021 03:46:41 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\DNNCE_RazorHost_09.03.02_Install.zip
06/14/2021 03:46:45 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\DNNCE_SiteExportImport_09.03.02_Install.zip
06/14/2021 03:46:46 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\DNNCE_SocialGroups_09.03.02_Install.zip
06/14/2021 03:46:49 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\DNNCE_Website.Deprecated_09.03.02_Install.zip
06/14/2021 03:46:49 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\GoogleAnalyticsConnector_09.03.02_Install.zip
06/14/2021 03:46:50 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Provider\DNNConnect.CKEditorProvider_01.00.05_Install.zip
06/14/2021 03:47:37 [INFO] DotNetNuke.Services.Installer.XmlMerge Start UpdateNode: keyAttribute=name
06/14/2021 03:47:52 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Provider\DNNCE_FolderProviders_09.03.02_Install.zip
06/14/2021 03:47:52 [INFO] DotNetNuke.Services.Installer.XmlMerge Start UpdateNode: keyAttribute=name
06/14/2021 03:47:53 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Provider\AspNetClientCapabilityProvider_09.03.02_Install.zip
06/14/2021 03:47:53 [INFO] DotNetNuke.Services.Installer.XmlMerge Start UpdateNode: keyAttribute=name
06/14/2021 03:47:53 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\Telerik_09.02.01_Install.zip
06/14/2021 03:47:56 [INFO] DotNetNuke.Services.Installer.XmlMerge Start UpdateNode: keyAttribute=path
06/14/2021 03:47:56 [INFO] DotNetNuke.Services.Installer.XmlMerge Start UpdateNode: keyAttribute=name
06/14/2021 03:47:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\JavaScriptLibrary\jQuery.zip
06/14/2021 03:47:57 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\Dnn.PersonaBar.AdminLogs_02.00.01_Install.zip
06/14/2021 03:47:59 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\Dnn.PersonaBar.ConfigConsole_02.00.01_Install.zip
06/14/2021 03:47:59 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\Dnn.PersonaBar.Connectors_02.00.01_Install.zip
06/14/2021 03:48:00 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\Dnn.PersonaBar.CssEditor_02.00.01_Install.zip
06/14/2021 03:48:01 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\Dnn.PersonaBar.Extensions_02.00.01_Install.zip
06/14/2021 03:48:02 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\Dnn.PersonaBar.Licensing_02.00.01_Install.zip
06/14/2021 03:48:03 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\Dnn.PersonaBar.Prompt_02.00.01_Install.zip
06/14/2021 03:48:04 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\Dnn.PersonaBar.Recyclebin_02.00.01_Install.zip
06/14/2021 03:48:06 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\Dnn.PersonaBar.Roles_02.00.01_Install.zip
06/14/2021 03:48:07 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\Dnn.PersonaBar.Security_02.00.01_Install.zip
06/14/2021 03:48:08 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\Dnn.PersonaBar.Seo_02.00.01_Install.zip
06/14/2021 03:48:09 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\Dnn.PersonaBar.Servers_02.00.01_Install.zip
06/14/2021 03:48:10 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\Dnn.PersonaBar.Sites_02.00.01_Install.zip
06/14/2021 03:48:11 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\Dnn.PersonaBar.SiteSettings_02.00.01_Install.zip
06/14/2021 03:48:12 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\Dnn.PersonaBar.SqlConsole_02.00.01_Install.zip
06/14/2021 03:48:14 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\Dnn.PersonaBar.TaskScheduler_02.00.01_Install.zip
06/14/2021 03:48:16 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\Dnn.PersonaBar.Themes_02.00.01_Install.zip
06/14/2021 03:48:17 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\Dnn.PersonaBar.Users_02.00.01_Install.zip
06/14/2021 03:48:18 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\Dnn.PersonaBar.Vocabularies_02.00.01_Install.zip
06/14/2021 03:48:19 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\JavaScriptLibrary\jQueryUI.zip
06/14/2021 03:48:20 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\JavaScriptLibrary\jQueryMigrate.zip
06/14/2021 03:48:20 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\Dnn.PersonaBar.Pages_02.00.01_Install.zip
06/14/2021 03:48:21 [INFO] DotNetNuke.Services.Upgrade.Upgrade Start InstallPackage:C:\home\site\wwwroot\Install\Module\Dnn.PersonaBar.SiteImportExport_02.00.01_Install.zip
Any information or assistance anyone can provide would be much appreciated, thank you!
From the log, it looks like you actually upgraded to DNN 09.03.02.
That being the case, please read the release notes for that version. This is the first release that removed a lot of deprecated methods, you you need to check your modules as it is likely that one or more of them need to be upgraded.
Look for upgrades that are OK for all current versions of DNN and you should be able to get to 9.9.1. There are other changes after 9.3.2, so you want to make sure that you have those covered, too.
For troubleshooting upgrades to DNN 9.2 and above:
- Check compatibility of all 3rd party extensions installed
- Uninstall all extensions not needed
- switch to DNN default skin (XCillion) for the upgrade
