Issue with Site Settings after upgrade to 9.2.2
Hi - I'm testing the upgrade process from DNN 9.1.1 to 9.2.2. I've uninstalled all unused modules and upgraded all the ones in use, and added the newtonsoft patch. Ran the upgrade and things are looking good and working well.
However, when I go to Settings >> Site Settings, something strange occurs - The blue "loading" bar that shows up on top of the "SiteSettings" window, just keeps flashing (this is the blue bar that says "it appears you have a slow connection" sometimes). In my case, it just keeps loading, again and again (the blue bar moves from left to right and then starts again). The connection isn't slow and it only happens in this (test) website running 9.2.2. It's happened both times I've tested the upgrade.
Any ideas what is causing this?
Tom
did you clear local browser cache?
Thanks for your reply Sebastian -
Yes, I have cleared local cache in browser, and I'm still seeing this behavior. (I'm seeing it in all browsers)
Any idea what might be causing this issue?
Thanks again
Tom
