DNN Upgrade to 9.04
Our DNN instance had a red 'critical update' message on the admin page so I went to run the update.  This led me to a page to upgrade to DNN9.04.  The upgrade ran smoth without errors but now one of our websites (Portal2) is no long bringing in content.  It displays an error 129 in the url.  Also on that page there is a login button at the bottom and when I click on it I get a blank pop up.
 http://supportsite.altara...20occurred&content=0
The errors I find in the Admin log are
AbsoluteURL:/DesktopModules/DigArticle/RSS.ashx
ExceptionGUID:ee72a213-7121-436e-8bb2-b9e33023e03b
AssemblyVersion:
PortalId:-1
UserId:-1
TabId:-1
RawUrl:
Referrer:
UserAgent:
ExceptionHash:fhCa9VKPL58mqNfWM6WA5YUVU+4=
Message:Method not found: 'System.String DotNetNuke.Entities.Modules.ModuleInfo.get_ModuleName()'.
StackTrace:
   at
DigNuke.DNN.Modules.DigArticle.ArticleModuleBase.InitVariables(String
where, Int32 currentModuleID, Int32 sourceModuleID, Boolean log, Boolean
 cache)
   at DigNuke.DNN.Modules.DigArticle.RSS.ProcessRequest(HttpContext
context)
InnerMessage:
InnerStackTrace:
Source:DigNuke.DNN.Modules.DigArticle
FileName:
FileLineNumber:0
FileColumnNumber:0
Method:
Server Name: ALT-WEB2
AND
AbsoluteURL:/default.aspx
ExceptionGUID:76220a20-7a0e-4e8c-9768-1ccf88a9a420
AssemblyVersion:9.4.0
PortalId:2
UserId:-1
TabId:129
RawUrl:/
Referrer:
UserAgent:Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/77.0.3865.90 Safari/537.36
ExceptionHash:bvonjHls1nVYKeCWukzc8qnxruo=
Message:The EnablePartialRendering property cannot be changed after the Init event.
StackTrace:
InnerMessage:The EnablePartialRendering property cannot be changed after the Init event.
InnerStackTrace:
   at System.Web.UI.ScriptManager.set_EnablePartialRendering(Boolean value)
   at DotNetNuke.UI.Modules.ModuleHost.LoadUpdatePanel()
   at System.Web.UI.Control.EnsureChildControls()
   at System.Web.UI.Control.PreRenderRecursiveInternal()
Source:
FileName:
FileLineNumber:0
FileColumnNumber:0
Method:
AND
ModuleId:900
ModuleDefId:176
FriendlyName:News
ModuleControlSource:DesktopModules/DigArticleListArticle/ListArticle.ascx
ExceptionGUID:dd6a8b3a-f339-4e23-826d-d95508f510e1
PortalId:2
UserId:-1
TabId:129
RawUrl:/
Referrer:
ExceptionHash:S8jETsxhbIWCXu1nobqO7ACkck4=
StackTrace:
InnerMessage:Method not found: 'System.String DotNetNuke.Entities.Modules.ModuleInfo.get_ModuleName()'.
InnerStackTrace:
   at
 cache)
   at DigNuke.DNN.Modules.DigArticle.ListArticle.Page_Load(Object
sender, EventArgs e)
Source:
FileName:
FileLineNumber:0
FileColumnNumber:0
Method:
AND
ExceptionGUID:5e226f3e-e1e2-438c-8e04-77e6e31b72a2
AssemblyVersion:
PortalId:-1
UserId:-1
TabId:-1
RawUrl:
Referrer:
UserAgent:
ExceptionHash:tQLubjXlksFRaVkyvLfednJoUdY=
Message:Unhandled Error Adding Module to SidebarBottom.
StackTrace:
   at DotNetNuke.UI.Skins.Pane.InjectModule(ModuleInfo module)
   at DotNetNuke.UI.Skins.Skin.InjectModule(Pane pane, ModuleInfo module)
InnerStackTrace:
   at
 cache)
   at DigNuke.DNN.Modules.DigArticle.Dashboard.OnInit(EventArgs e)
   at System.Web.UI.Control.AddedControl(Control control, Int32 index)
   at DotNetNuke.UI.Modules.ModuleHost.InjectModuleContent(Control
content)
   at DotNetNuke.UI.Containers.Container.get_ModuleControl()
   at DotNetNuke.UI.Containers.Container.ProcessModule()
Source:DotNetNuke
FileName:
FileLineNumber:0
FileColumnNumber:0
Method:
I could go on and on but there are about 90 of them.  The weird thing is....we have another site on a different portal that came up just fine, I can login and all the content shows up.
I would appreciate any help I can get!!
Thanks,
Heather
It looks like you need to upgrade digArticle. Get in touch with Mike (at digNuke) for help with this.
Likely, the best way to do this is to revert your installation, update digArticle (and any other modules that need upgrading) and try the DNN upgrade again. Note that you should continue and upgrade to DNN 9.4.1 as the will fix some errors in 9.4.0.
