istabpreview error on upgrade from 9.1.1 to 9.3.2
i see this on every module when i upgrade from 9.1.1 to 9.3.2 or directly to 9.5
Error: USER EXPERIENCE is currently unavailable. DotNetNuke.Services.Exceptions.ModuleLoadException: h:\root\home\mhamlett-001\www\site1\DesktopModules\HTML\HtmlModule.ascx(109): error CS0117: 'DotNetNuke.Common.Globals' does not contain a definition for 'IsTabPreview' ---> System.Web.HttpCompileException: h:\root\home\mhamlett-001\www\site1\DesktopModules\HTML\HtmlModule.ascx(109): error CS0117: 'DotNetNuke.Common.Globals' does not contain a definition for 'IsTabPreview' at System.Web.Compilation.BuildManager.PostProcessFoundBuildResult(BuildResult result, Boolean keyFromVPP, VirtualPath virtualPath) at System.Web.Compilation.BuildManager.GetBuildResultFromCacheInternal(String cacheKey, Boolean keyFromVPP, VirtualPath virtualPath, Int64 hashCode, Boolean ensureIsUpToDate) at System.Web.Compilation.BuildManager.GetVPathBuildResultFromCacheInternal(VirtualPath virtualPath, Boolean ensureIsUpToDate) at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate) at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath) at DotNetNuke.UI.ControlUtilities.LoadControl[T](TemplateControl containerControl, String ControlSrc) at DotNetNuke.UI.Modules.WebFormsModuleControlFactory.CreateControl(TemplateControl containerControl, String controlKey, String controlSrc) at DotNetNuke.UI.Modules.WebFormsModuleControlFactory.CreateModuleControl(TemplateControl containerControl, ModuleInfo moduleConfiguration) at DotNetNuke.ModulePipeline.ModuleControlPipeline.LoadModuleControl(TemplateControl containerControl, ModuleInfo moduleConfiguration) at DotNetNuke.UI.Modules.ModuleHost.LoadModuleControl() --- End of inner exception stack trace ---
i have verified that all dnnsharp modules are upgraded to lastest versions they recommend. they say it isnt them. i contacted the theme designer to get a 9.5 version and installed it. i even removed the theme and uninstalled their modules. no luck
this site is as barebones as i can make it. only a few dnnsharp modules and gravity skin.
i have also tried going directly to 9.5 and 9.6 with same results.
Did you install the DNN sharp modules before or after the upgrade?
before
i installed the upgraded skin and modules at 9.1.1
i was getting "TOO MANY REDIRECTS" trying to upgrade without upgrading the modules and skin.
I'm not sure, but isn't MyTokens making changes to the HTML module?
(that would mean you would have to install it after the DNN upgrade)
so i guess i could reinstall the modules after the upgrade. i didnt try that
it seems they have to be installed the upgrade, otherwise i get the too many redirects error.
You can install the modules during the upgrade. Just copy the install/upgrade packages of the modules into the /install/modules folder (between step 3 and 4 of these instructions. This will upgrade the modules during the DNN upgrade process.
