JQuery 3.5.0 DNN 9.6.0
JQuery 3.5.0 introduced few breaking changes
https://github.com/twbs/bootstrap/issues/30553
https://github.com/jquery/jquery/issues/4665
How I can revert to JQuery 3.4.1 but keep DNN 9.6.0 util the 3.5.1 will be released?
From Peter Donker at Slack " The workaround is to manually fill in a url (like a CDN) under Extensions > Javascript Libraries > Select jQuery and then go to extension settings. You can fill in a Custom CDN there.
I have used https://ajax.googleapis.c.../3.4.1/jquery.min.js but it does not work.
I had to insert directly in the skin
03.05.01 has just been released
http://blog.jquery.com/20...fixing-a-regression/
Posted By Mariette Knap on 02 May 2020 07:20 AM
I just tested that and that does not help, DNN still loads jQuery 03.05.00 even with a custom CDN to 03.05.01
I copied the content of jQuery 03.05.01 into the file \Resources\Libraries\jQuery\03_05_00\jquery.js, that's a hack, but does work
https://dnncommunity.org/blogs/Post/5401
