upgrade from 9.1.1 to 9.3.0
Page 1 of 41234 > >>
while trying to upgrade evoq 9.1.1 to 9.3.0, I rreceived the following error and now cant get to any site
Compilation Error
Description: An error occurred during the compilation of a resource required to service this request. Please review the following specific error details and modify your source code appropriately.
Compiler Error Message: BC30456: 'GetUserRolesByRoleName' is not a member of 'DotNetNuke.Security.Roles.RoleController'.
Source Error:
<code>
Line 496:            Dim roleCont As New DotNetNuke.Security.Roles.RoleController
Line 497:
<font color="red">Line 498:            Dim roleArr As ArrayList = roleCont.GetUserRolesByRoleName(PortalId, RoleName)
</font>Line 499:
Line 500:            For Each info As DotNetNuke.Entities.Users.UserRoleInfo In roleArr</code>
Source File: \\Server01\DNN\App_Code\effority.UserDirectory\Controller.vb    Line: 498
I hope you did a backup before you upgraded?
In DNN 9 there has been quite a cleanup of the code.
A lot of legacy code (that was marked as legacy for years) has been removed.
The effority user module is most likely using one of those and AFAIK this module is not developed any more.
You have 2 options.
A. Uninstall the module before you upgrade (and look for an alternative module, if needed)
B. Find the source of the module and fix the compatibility issues.
I'm not 100% sure, but I think the source can be found here: https://archive.codeplex.com/?p=userdirectory
Timo's advice is sound. In addition, I'd suggest the following:
- Restore to the original website before the upgrade.
- Uninstall any non-core extensions that aren't in use
- Upgrade any non-core extensions that have updates available (even and especially the commercial ones, which may require new license fees)
- Upgrade from 9.1.1 to 9.2.2 first.
- Test and ensure everything went well
- If everything is good-to-go and tests well, now upgrade from 9.2.2 to 9.3.2
DNN Platform 9.2.2: https://github.com/dnnsof.../releases/tag/v9.2.2
Just in case it helps, here's a presentation I did at DNN Summit recently. It walks you through some of the upgrade processes we follow.
https://www.slideshare.ne...mple-dnn-summit-2019
Also, when you get to the step of 9.3, use 9.3.2 instead of 9.3.0 to get the latest fixes, some of which had to do with upgrades. But yes, that specific issue you are having is related to the module.
thank you all for your suggestions. the user directory module is not being used. I will remove it and try the upgrade again.
@Daniel: we are only seeing evoq 9.3.0 on our download portal and per DNN support that is the latest version available.
Posted By alexio1 on 24 Jun 2019 10:00 AM
That's correct, and I'm not aware of when Evoq might have their next release. :(
Iam getting ready to remove the user directory module, do I need to check delete Files?
Posted By alexio1 on 24 Jun 2019 01:19 PM
First, be sure you back up the website files and database.  Next, in general, I'd tell you that you'd always want to delete the files.
The only time I don't delete the files is when I know there is a shared file I need to keep (e.g., a shared DLL in the bin folder).  Even then, I'd go in and manually delete everything else, as necessary.
do you know what directories the module files are stored in beside desktopmodules?
Posted By alexio1 on 24 Jun 2019 02:24 PM
Usually, only the DesktopModules and Bin folders. Sometimes, you'll find some of the module files in the App_Data folder as well, but it depends on the module itself.  Occasionally, you'll find files related to the module in the Portals folders, but those files are usually not something that would impact the website in any way.  It really depends on the module.
