Upgrade from 9.13.9 failed: Method not found DotNetNuke.Abstractions.Security.ICryptographyProvider.EncryptParameter
I'm trying to upgrade a DNN site from 9.13.9 to latest 10x and when I do the upgrade to 10.2.5 I get this error below.
Anyone seen this before? Any ideas?
Method not found: 'System.ValueTuple`2 DotNetNuke.Abstractions.Security.ICryptographyProvider.EncryptParameter(System.String, System.String)'.
Exception Details: System.MissingMethodException: Method not found: 'System.ValueTuple`2 DotNetNuke.Abstractions.Security.ICryptographyProvider.EncryptParameter(System.String, System.String)'.
[MissingMethodException: Method not found: 'System.ValueTuple`2 DotNetNuke.Abstractions.Security.ICryptographyProvider.EncryptParameter(System.String, System.String)'.]
   DotNetNuke.Web.Common.Internal.DotNetNukeHttpApplication..cctor() +0
[TypeInitializationException: The type initializer for 'DotNetNuke.Web.Common.Internal.DotNetNukeHttpApplication' threw an exception.]
   ASP.global_asax..ctor() +17
[TargetInvocationException: Exception has been thrown by the target of an invocation.]
   System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck) +0
   System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark) +122
   System.RuntimeType.CreateInstanceDefaultCtor(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark) +239
   System.Activator.CreateInstance(Type type, Boolean nonPublic) +85
   System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes, StackCrawlMark& stackMark) +1173
   System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes) +130
   System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture) +21
   System.Web.HttpRuntime.CreateNonPublicInstance(Type type, Object[] args) +59
   System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context) +148
   System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext) +303
[HttpException (0x80004005): Exception has been thrown by the target of an invocation.]
   System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +657
   System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +89
   System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +189
Vicenç Masanas
Disgrafic ITec SL Banyoles - Spain
Seems i found the issue: I had to update System.ValueTuple.dll to a newer version, 4.5.0
Once done, the upgrade worked
Vicenç Masanas
Thanks for the update! Will save more people a lot of time :-)
