Upgrade from DNN 9.03.02 to 9.05.00 personaBar gives 500 error on multiple admin sections
After I upgraded my website from DNN 9.03.02 to 9.05.00 personaBar gives 500 internal server error on multiple admin sections: for example on Pages section.
/API/PersonaBar/Pages/GetContentLocalizationEnabled
error:
  1. Message: "An error has occurred."
  2. ExceptionMessage: "An error occurred when trying to create a controller of type 'PagesController'. Make sure that the controller has a parameterless public constructor."
  3. ExceptionType: "System.InvalidOperationException"
InnerException:
  1. ExceptionMessage: "Unable to resolve DotNetNuke.Abstractions.INavigationManager as parameter "navigationManager" ↵ in scoped Dnn.PersonaBar.Pages.Services.PagesController. ↵Where no service registrations found ↵ and number of Rules.FallbackContainers: 1 ↵ and number of Rules.UnknownServiceResolvers: 0"
  2. ExceptionType: "DnnSharp.DryIoc.ContainerException"
No idea anyone?
I had the similar issue with admin about 10 days ago.  I also had a problem with the Gravity theme displaying.  After a couple of days of having almost 20 sites that had issues I restored my sql backup and my directory backup.  I have been working on upgrading a new backup of the system but so far have not got one to work in every aspect.
One think I forgot to do the first time around was to upgrade EVERY module/extension and theme before I tried the upgrade.  That solved some problems.
Hopefully you have a backup of the original sql and the directory. Good luck.
Are you using the right version of .NET on the upgraded installation? I think that you need 4.7.2.
Yes, I  intalled .net framework to 4.7.2 before starting the upgrade.
Posted By Andrei Coman on 10 Apr 2020 05:58 PM
  1. ExceptionType: "DnnSharp.DryIoc.ContainerException"
You may want to contact DNNSharp?
