Upgrade to 10.1.0 - Error dropping vw_ApiTokens
The database script errors at 3%  with the following:-
3% ERROR occured - System.Data.SqlClient.SqlException (0x80131904): Incorrect syntax near the keyword 'IF'. at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) at System.Data.SqlClient.SqlCommand.RunExecuteNonQueryTds(String methodName, Boolean async, Int32 timeout, Boolean asyncWrite) at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry) at System.Data.SqlClient.SqlCommand.ExecuteNonQuery() at DotNetNuke.Data.SqlDatabaseConnectionProvider.ExecuteNonQuery(String connectionString, CommandType commandType, Int32 commandTimeout, String query) at DotNetNuke.Data.SqlDataProvider.ExecuteScriptInternal(String connectionString, String script, Int32 timeoutSec) ClientConnectionId:15a589d1-9a23-4525-926a-f4aa545c6ea5 Error Number:156,State:1,Class:15 DROP VIEW IF EXISTS dbo.[vw_ApiTokens]
From what version are you upgrading?
Did you follow the suggested upgrade path?
9.11 - It's old test install of DNN without any extensions.
There is no vw_apiTokens view in the database
Check which sql version you are running. I think DROP VIEW IF EXIST is only in sql 2016 which is now minimum sql version in dnn 10.
Could the answer as its still on SQL 2012, will need to upgrade it first
I think there's a 99% chance that's the issue. ;-)
By the way, thank you for posting this, it might help other users experiencing the same problem.
I have seen a few issues with some people running SQL 2012, I suggest your first step should be to upgrade to at least SQL 2016.
I've upgraded to SQL 2016 and the database script has now completed. I now need to restore the database and web folders back to their original state and re-try the update again.
I really need to get around to updating my ancient test server to something more suitable.
