When I load the Home page of this site (www.flying15.org.uk) I see in the the console 404 errors associated with this module.
The site has been upgraded from 7.4.2 to 9.3.2. Might this asset have been omitted from the upgrade?
What do I do about this?
Pls add <code><add key="DnnImageHandler" value="EnableServerCache=false;"><add></add></add></code> to appsettings in web.config
see my post http://www.dnnsoftware.co...ts/dnn-image-handler
<code><add key="DnnImageHandler" value="EnableServerCache=false;"></add></code>
Hi Mariette, That is already there. I also have; add name="DnnImageHandler" path="DnnImageHandler.ashx" verb="*" type="DotNetNuke.Services.GeneratedImage.DnnImageHandler, DotNetNuke" preCondition="integratedMode" Does this make a difference?
The console shows DnnImage Handler asking for;
https://flying15.org.uk/D...c&userId=1&h=32&w=32
So, do I assume DnnImageHandler is not what is missing, but the profile picture at the location expected?
And where would that be?
OK, so the 404 error was resolved by placing the line
add name="DnnImageHandler" path="DnnImageHandler.ashx" verb="*" type="DotNetNuke.Services.GeneratedImage.DnnImageHandler, DotNetNuke" preCondition="integratedMode" /
in the correct section.
I now get an Error 500. The image being called for is /DesktopModules/~/Icons/Sigma/Users_32x32_Standard.png
However the Icon files were not at that location but at /Icons/Sigma
I copied them to the exxpected location but that is when I get the 500 error.
Any suggestions?
es and I did that. As my last post mentioned, I am now in Error 500 territory for the icon files for profiles.
Simon,
this is strange. It works fine here with me, but this is not helpful...
Here are the lines from my web.config:
<_ configuration _> [...] <_ appSettings _> [...] <_ add key="DnnImageHandler" value="EnableServerCache=false;" / _> [...] <_ /appSettings _> [...] <_ system.webServer _> [...] <_ handlers _> [...] <_ add name="DnnImageHandler" path="DnnImageHandler.ashx" verb="*" type="DotNetNuke.Services.GeneratedImage.DnnImageHandler, DotNetNuke" preCondition="integratedMode" / _> [...] <_ /handlers _> [...] <_ /system.webServer _> [...] <_ /configuration _>
When there is no avatar available, the handler should show some gray head without a face as the default image for profile pictures.
Hope that helps.
Happy DNNing! Michael
Hi Michael, and thanks fo the response.
I finally got those lines in the correct place in the config file and all works as you say.
As I went on the say, the standard icons now fail to load with Error 500. I think these are called by the skin and it asks for them from the DNN7 location and not the DNN9 location. I have duplicated the icon folder and contents where the skin is asking for them from. See my post prior to yours for the URLs.
Regards
Posted By Simon Thompson on 03 Dec 2019 07:09 AM [...] I now get an Error 500. The image being called for is /DesktopModules/~/Icons/Sigma/Users_32x32_Standard.png [...]
first, I am glad we solved the configuration problems from the web.config file.
The path (that I quoted) is really strange, and I have no idea where it comes from.
"~/Icons/Sigma/Users_32x32_Standard.png" is some syntax in ASP.Net that it should start in the root of the application (which is normally "/Icons/Sigma/..."). The "/DesktopModules/" in front of it does not make any sense, where is the origin of that? What module are we talking about? Or could that be an issue of the skin, or a skin object?
