Issue configuring oAuth for SMTP Authentication
Page 2 of 2 << < 12
Posted By Daniel Valadas on 9/5/2024 7:04 PM
If you figure out all the proper setup to make it work, we would greatly benefit from having that process documented :) I could never make it work with exchange.
I will :-)
Posted By johnhenley on 9/5/2024 7:34 PM
Is the 503 error on DNN side? Or exchange?
What type of certificate are you using for DNN? And is the DNN endpoint accessible publicly?
I ended up on this page which showed a 503 error.
https://www.website.com/P...nline/Authorize.aspx
Using a Letsncrypt certificate.
Yes
We used a workaround for now but I'll tray again in about a week.
I think I can describe how to make it work with Exchange online. It is quit simple when you know that you have to use Microsoft Graph
  • In DNN
    • Personabar - Security - More - SSL Settings:
      Make sure that SLL Settings = ON
  • In Exchange
    • Create a mailbox with al licence.
  • In Azure
    • Create an App registration
      • Redirect URIs:
        • https://[DOMAINNAME]/Providers/SmtpOAuthProviders/ExchangeOnline/Authorize.aspx
      • Secret
      • API Permissions
        • Microsoft Graph
          • Delegated -> SMTP.Send (Send emails from mailboxes using SMTP AUTH)
  • In DNN
    • Servers - Seversettings - SMTP Server
      • SMTP Sever and Port = smtp.office365.com:587
      • SMTP Authentication= OAuth
      • Auth Provider = Exchange online
      • Tenant Id = [Directory (tenant) ID]
      • Client Id = [Application (client) ID]
      • Client Secret = [client secret value]
    • Save Settings
    • Authorize
      • Using the Microsoft Mailbox credentials
    • Test SMTP Settings
Thank you Mr Needle for adding the procedure to the DNN Documentation :-)
https://docs.dnncommunity.org/content/tutorials/server/smtp-servers/set-up-oauth-microsoft-365/index.html
I have version 09.06.01 and I don't have these options
Page 2 of 2 << < 12
