Troubleshooting scheduled task hanging after completion DNN 7.4.2
Isa
Recently, a task has started to hang around after completion. It is happening just for this task, just in this install, and I don't understand why.
Not sure how relevant this will be. The task is scheduled to run every 30 minutes. But it can also be scheduled by another task or database connection timeout via:
var schedulingProvider = SchedulingProvider.Instance();
var scheduleItem = schedulingProvider.GetSchedule(typeFullName, null);
schedulingProvider.RunScheduleItemNow(scheduleItem, true);
The task is fairly basic:
1. Load queued records
2. Call the stored procedure on every record
3. Exit
Task can terminate early if SQL connection times out. After which, the task would attempt to reschedule itself.
Most of the time, the task has nothing to do. It completes in a fraction of a second (0.10 - 0.19 seconds).
Recently, the task started to hang ever other time. Each time I manually stop the task in the Schedule Status window, it would have STARTED_FROM_SCHEDULE_CHANGE in the Triggered by column. My understanding is that this indicates the task was started by either the Edit Schedule window (Update or Run Now buttons) or from the SchedulingProvider instance's RunScheduleItemNow method.
At first I thought the task was getting lost by the worker process. I added (SchedulerClient) Progressing calls to the batch processing loop in the hope that it would update ScheduleHistory.LogNotes as it runs and keeps the worker process happy. But nothing changed, so I thought the task was not executing at all. I added logging to every method that is entered and exited. Now, each time the task runs, I get the following:
2026-03-18 10:19:08,271 [WebSvr02][Thread:178][ERROR] DotNetNuke.Services.Exceptions.Exceptions - System.Exception: Entered DoWork method
2026-03-18 10:19:08,271 [WebSvr02][Thread:178][ERROR] DotNetNuke.Services.Exceptions.Exceptions - System.Exception: Entered ExecuteAcademicRatioUpdate method
2026-03-18 10:19:08,271 [WebSvr02][Thread:178][ERROR] DotNetNuke.Services.Exceptions.Exceptions - System.Exception: Entered ProcessQueue method
2026-03-18 10:19:08,271 [WebSvr02][Thread:178][ERROR] DotNetNuke.Services.Exceptions.Exceptions - System.Exception: Entered ProcessBatch method
... snip loop logs for brevity ...
2026-03-18 10:19:08,490 [WebSvr02][Thread:178][ERROR] DotNetNuke.Services.Exceptions.Exceptions - System.Exception: Exiting ProcessQueue method
2026-03-18 10:19:08,490 [WebSvr02][Thread:178][ERROR] DotNetNuke.Services.Exceptions.Exceptions - System.Exception: Exiting ExecuteAcademicRatioUpdate method
2026-03-18 10:19:08,490 [WebSvr02][Thread:178][ERROR] DotNetNuke.Services.Exceptions.Exceptions - System.Exception: Entered HandleSuccess method
2026-03-18 10:19:08,490 [WebSvr02][Thread:178][ERROR] DotNetNuke.Services.Exceptions.Exceptions - System.Exception: Exiting HandleSuccess method
2026-03-18 10:19:08,490 [WebSvr02][Thread:178][ERROR] DotNetNuke.Services.Exceptions.Exceptions - System.Exception: Exiting DoWork method
This confirmed that the task runs and the DoWork method completes. At which point I expect the worker process to move on to the next task.
I don't know if it is related, but my DoWork method is currently implemented as follows:
public override void DoWork()
    Exceptions.LogException(new Exception("Entered DoWork method"));
    var executionResult = ExecuteAcademicRatioUpdate();
    if (executionResult.TimeoutOccurred)
        HandleTimeout(executionResult);
    else if (executionResult.HasErrors)
        HandleErrors(executionResult);
    else
        HandleSuccess(executionResult);
    Exceptions.LogException(new Exception("Exiting DoWork method"));
Any suggestions are much appreciated.
Isa
I resolved the issue by refactoring my DoWork method.
Namely, I ditched HandleTimeout altogether and wrapped HandleSuccess and HandleErrors in a try..catch block as per examples.
I also removed all Progressing methods as these don't seem to do anything.
I tried Started and Completed methods. They worked, but the task kept rescheduling itself as soon as it was completed. Causing issues with the scheduler thread. Where active/free thread count would go negative. This results in multiple tasks running simultaneously.
Reference:
Creating Scheduled Jobs - https://www.dnnsoftware.c...ating-scheduled-jobs
DotNetNuke Scheduler (Schedule a Task in DNN) - https://www.dnndeveloper....hedule-a-task-in-dnn
