Unable to upload images.
DNN 9.3, At first the site worked perfectly, but after it being aloive for a couple of weeks without any image related issues, for some reason, now, I, nor my users can upload images, or videos. I do the upload steps, it lets me browse the computer, click on the image or video I want, but when it comes to the step "Send to server", that's where the problem is, it just gives a flag that says "Image source URL is missing" and blocks me from that point on.. And in the Journal, the upload progress bar goes to 100%, but it never let's me upload the images.
 Any ideas?
I just did a quick search in the source and I don't see that message anywhere. Would you be able to provide a screenshot to help us track this down?
Posted By Will Strohl on 20 Jun 2019 02:59 PM
Yes, but do I need to add them to my hosting and post the URL's or is there a way to upload the images (screenshots)? I clikced on the image button, but it only asks for the URL.
There are some free tools that could allow you to do this, such as Jing.
Well, no luck posting pics here. Any other ideas since it seems that feature is turned off? I get it that it's a security hing, but makes it hard to show what's going on.
Posted By Jeff on 20 Jun 2019 05:23 PM
If you use a tool like Jing (there are many alternatives), you can simply generate and post a link to your screenshot.
https://www.techsmith.com/jing-tool.html
I actually check the admin logs, this is one of the codes that looks like it may be related.
AbsoluteURL /Providers/HtmlEditorProviders/DNNConnect.CKE/Browser/FileUplo
AbsoluteURL:/Providers/HtmlEditorProviders/DNNConnect.CKE/Browser/FileUploader.ashx
DefaultDataProviderotNetNuke.Data.SqlDataProvider, DotNetNuke
ExceptionGUID:297b9839-94e1-4784-b84c-f7bdd0891a89
AssemblyVersion:
PortalId:-1
UserId:-1
TabId:-1
RawUrl:
Referrer:
UserAgent:
ExceptionHash:LrufcsCJAEUrAuT+LAxwX9v/kKc=
Message:Unhandled Error:
StackTrace:
InnerMessage:The underlying system threw an exception. The file has not been added.
InnerStackTrace:
at DotNetNuke.Services.FileSystem.FileManager.AddFile(IFolderInfo folder, String fileName, Stream fileContent, Boolean overwrite, Boolean checkPermissions, Boolean ignoreWhiteList, String contentType, Int32 createdByUserID) at DotNetNuke.Services.FileSystem.FileManager.AddFile(IFolderInfo folder, String fileName, Stream fileContent, Boolean overwrite, Boolean checkPermissions, String contentType, Int32 createdByUserID) at DNNConnect.CKEditorProvider.Browser.FileUploader.UploadWholeFile(HttpContext context, List`1 statuses) at DNNConnect.CKEditorProvider.Browser.FileUploader.UploadFile(HttpContext context) at DNNConnect.CKEditorProvider.Browser.FileUploader.HandleMethod(HttpContext context) at DNNConnect.CKEditorProvider.Browser.FileUploader.ProcessRequest(HttpContext context) at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() at System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step) at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
Source:
FileName:
FileLineNumber:0
FileColumnNumber:0
Method:
Server Name: P3NWVPWEB003
Aniel Tracking Website
AbsoluteURL /DnnImageHandler.ashx DefaultDataProvider DotNetNuke.Data.SqlD
AbsoluteURL:/DnnImageHandler.ashx
ExceptionGUID:8d19f8a8-9235-41d8-b440-c8b92731be41
AssemblyVersion:
PortalId:-1
UserId:-1
TabId:-1
RawUrl:
Referrer:
UserAgent:
ExceptionHash/KKZ3qBHQwdBEy9W3GfiAiBy6k=
StackTrace:
InnerMessage:The process cannot access the file 'G:\PleskVhosts\nashvilleskydiving.net\paulaniel.com\App_Data\_imagecache\8FF1A5334A338B216D196BDCB73A96130B1C7B1D.tmp' because it is being used by another process.
InnerStackTrace:
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share) at System.Web.HttpResponse.TransmitFile(String filename, Int64 offset, Int64 length) at System.Web.HttpResponseWrapper.TransmitFile(String filename) at DotNetNuke.Services.GeneratedImage.DiskImageStore.TryTransmitIfContains(String id, HttpResponseBase response) at DotNetNuke.Services.GeneratedImage.DiskImageStore.DotNetNuke.Services.GeneratedImage.IImageStore.TryTransmitIfContains(String id, HttpResponseBase response) at DotNetNuke.Services.GeneratedImage.ImageHandlerInternal.HandleImageRequest(HttpContextBase context, Func`2 imageGenCallback, String uniqueIdStringSeed) at DotNetNuke.Services.GeneratedImage.ImageHandler.ProcessRequest(HttpContextBase context) at DotNetNuke.Services.GeneratedImage.ImageHandler.ProcessRequest(HttpContext context) at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() at System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step) at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
Source:
FileName:
FileLineNumber:0
FileColumnNumber:0
Method:
The Official Paul Aniel Tracking Website
AbsoluteURL /DesktopModules/editBar/common/API/Common/CheckAuthorized Defa
AbsoluteURL:/DesktopModules/editBar/common/API/Common/CheckAuthorized
ExceptionGUID:6b92958a-61c6-475e-9968-6e3b6ab349a1
AssemblyVersion:
PortalId:-1
UserId:-1
TabId:-1
RawUrl:
Referrer:
UserAgent:
ExceptionHash:urAEcWVC+Dt+N6+Bva8vmwC+1w8=
Message:A task was canceled.
StackTrace:
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Tracing.ITraceWriterExtensions.d__18`1.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Controllers.ApiControllerActionInvoker.d__0.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Tracing.ITraceWriterExtensions.d__18`1.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Controllers.ActionFilterResult.d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.AuthorizationFilterAttribute.d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.AuthorizationFilterAttribute.d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Controllers.ExceptionFilterResult.d__0.MoveNext()
InnerMessage:
InnerStackTrace:
Source:mscorlib
FileName:
FileLineNumber:0
FileColumnNumber:0
Method:
Sorry those are so long, but that's the three main error messages it has.
