Where can I specify the jQuery download location
I have trouble finding the setting for jQuery. The site in question 'auto-magically' uses the "code.jquery.com" location. The client wants to use the local/resources version. Where do I set this? There use to be setting in the hostsettings table, but I am not able to find it, nore did I find something in the database.
Thanks for your help
This is a popular question, perhaps we should add it to the docs.
Meanwhile, here's the answer: https://stackoverflow.com/a/60540544
Paras Daryanani
Celestify
Celestify - we build digital ecosystems.
Thanks, I missed this property...
Check hostsettings table:
-- select * from hostsettings where settingname='cdnenabled'
-- update hostsettings set settingvalue ='N' where settingname='cdnenabled'
As there seems to be no checkbox, to set or remove the use of the cdn version
