After attempted upgrade (10.00.01 → 10.01.01), clicking Update in HTML module crashes site and triggers JIT debugging
 33 Subscribed to this forum
DNN Platform: 10.00.01 (attempted in-place upgrade to 10.01.01)
Behavior: No installer errors reported, but editing any HTML/Pro module and clicking “Update” crashes the site. The server then prompts Visual Studio Just-In-Time debugging (VS tries to attach to w3wp). Front-end recovers after app pool recycles.
probably attempt again today.
There is no HTML/Pro on DNN Platform, I guess you are on evoq?
If so, either:
- You can't just install the Platform upgrade package on it as they do customizations, so you need to get upgrades from them.
- Or you have already migrated from Evoq to Platform but there are some leftovers from Evoq still in place.
sorry just regular html module
I don't see an Update button in the normal html module usage, where do you see that?
We need a bit more info in order to help, can you list exact steps to recreate the issue and also provide some logs, if it tries to attach to the debugger, you probably have visual studio installed, so you could accept and check if you see any exceptions there. You can also check the Site Logs or the log files at Portals\_default\logs for potential clues.
Ill attempt the upgrade again now maybe I can provide more information.
im not upgrading the html module im upgrading DNN. When I edit anything on any page it hangs and the site crashes. Give me some time to attempt the ugprade again maybe I can provide more logs/info.
upgrade to dnn loged in try to edit anything get the html module page hit update or sumbut after adding test text and hit sumbit. takes me to the same page after some time and html raw mode below.
I found this bug after upgrade, it might be related.
https://github.com/dnnsof...Platform/issues/6740
Follow the discussion link in it and there is a fix for it.
Thanks David Ill try it today and get back to you.
