Default.aspx?tabid=21&error=An unexpected error has occurred&content=0
Upgraded to ver 10 and when I clicked view website I see this message in the browser address bar. Anyone know how to fix this? SQL server v 2017. .NET 4.8.0
What errors do you see in Portals/_default/Logs/2025.04.[today].log.resources ?
I have a bunch of
DotNetNuke.Services.Exceptions.PageLoadException: Unhandled error loading page. ---> System.Runtime.InteropServices.ExternalException: Cannot execute a program. The command being executed was "W:\vhosts\\httpdocs\bin\roslyn\vbc.exe" /shared /keepalive:"10" /noconfig @"W:\vhosts\\tmp\root\ea856d5a\df8b8f0e\fwf1gr4m.cmdline". ---> System.ComponentModel.Win32Exception: This program is blocked by group policy. For more information, contact your system administrator
also
2025-04-10 00:00:07.198+08:00 [Wincloud01-AU][D:2][T:21][ERROR] DotNetNuke.Services.Exceptions.Exceptions - ~/Default.aspx?tabid=21&error=terminate
at DotNetNuke.Framework.DefaultPage.GetSkin()
at System.Web.UI.Control.d__225.MoveNext()
The most likely issue is that the Theme contains a deprecated Theme object.
Can you try this link? https://yourwebsite.com/?...ins/aperture/default
So add ?SkinSrc=[G]skins/aperture/default after the domainname?
Thank you, the site opened. I am logging in to set the aperture skin the skin of choice and will just have to do a little rebuilding. Hmmm, trying to log in crashed the site back to a 503 error. Can I edit the PortalAlias table to add a skin identifier?
In response to the first error, the host responded
During the recent security audit and process, we have placed restrictions that prevent certain file types from being uploaded or used on the server. This includes files with extensions such as .exe, .ps1, .yaml, and others commonly associated with scripts or application installers.
FSRM policy enforces file-screening rules, and prevents unauthorized or risky file types, contributing to security and operational stability.
To ensure the continued functionality and security of your website, you will need to recompile and redeploy the website using an alternative approach that complies with these restrictions. This may involve modifying script formats, using compressed archives, or replacing certain executable files with secure server-side equivalents.
Yes, you can edit the PortalsSettings Table for that.
In general the issue in your existing skin should be easy to fix, but you might have to replace some skin objects with more modern options.
You can restrict file upload extensions from DNN using the security settings. "Settings>Security>More>More Security Settings>Allowable File Extensions". Those extensions you have mentioned are NOT in the list by default, so you should be OK. Of course this will only apply to uploaded through DNN and Module installation is excluded from these settings.
We also have a monitoring script that works sperate from DNN that checks the DNN folders for any invalid/strange extension types and alerts us of any possible attack. This is a nice approach for extra security.
Of course other options exist, it all depends on how tight you want the security, compared to the flexibility for users.
Bottom line here.
Although the host supports CodeDom they also block all exe file activity on their servers so DNN cannot invoke vdc to write their page scripts. I have accessed the site using the query string Timo offered above on every page, and copied basic functionality across to a local 9.13.08 install. I will have to wipe all files from the host and upload the local version as a new site. V10 is not going to work for me till I change host.
David, while this is true it does not get around the fact that v10 needs to run exe files on the server and host policy now prevents it from doing that. I have relaunched a reduced v9.13.8 site and will work with that for as long as I stay with this host.
