Mobius Forms v5 with Mailchimp, Recaptcha and more
You are not authorized to post a reply.
    Just checking in....
    I have designed apps like this but the form content was turned into an email and emailed out.
    I am hoping this app does that - but I cannot figure out what configuration allows me to do that...
    I might be delusional - help
      I haven't used that specific module and feature to do what you're asking about, but I'm sure it will work. It's also one of at least a handful of options I can think of to accomplish the requirements you've listed so far. :)
        As Will mentions, there are several commercial and open-source solutions to potentially achieve this type of integration/solution. Can you share a bit more about your specific use case? Perhaps we can help guide you further at that point.
