DNN 9.13.x in Azure WebApp multi-tenanted with isloated DBs and shared / single codebase
 28 Subscribed to this forum
I've been playing with and using DNN since the very early days when it ran in ASP with an Access database!
I've used it for intranets and company web sites and I really love it.
I'm now busy developing some custom modules and needing to run things in Azure WebApps (as per customer requirements).
I've read that DNN can be installed in Azure WebApp as a multi-tenanted system such that each tenant has its own database and DNS entry (subdomain).
Basically, I'd like to install DNN once, install some customer modules I'm developing once, and have multiple tenants access the software,but keeping each tenant's data completely isolated from each other. Each tenant will have their own sub-domain (tenant1.mydomain.com and tenant2.mydomain.com) thus accessing their own portal.
I'd like to know:
  1. Is this type of installation possible?
  2. How do I go about performing this type of install / configuration for multiple tenants?
  3. Is there any way to simulate this on a local PC running under IIS on my DEV PC?
  4. Is there anything else I need to know about this?
Thanx,
Alon
in one DNN instance, a single SQL Server database is used.
Even with mutiple sites within it, you cannot use multiple databases, sorry.
You wou need to use individual DNN instances per site for your requierement.
Each may have different DNN versions and extensions (modules. skins etc) installed.
Alon,
  1. Afaik (but maybe someone knows better): No. It is possible to have different portals in one installation, but they all are using the same database (separated by the PortalID). It is also possible to use the same database for different installations (using the concept of the "object qualifier"), but as nowadays there is no real need for that anymore it is a bit tricky to install (the installation routine does not give you the option) - and it is one of the most misunderstood features in DNN, so it is not actively promoted anymore.
  2. The answer above should say it...
  3. As it is not a feature of DNN: no. (btw: to set up a testing environment on your local PC you can use the dnndev.me domain with any server name. It always points to 127.0.0.1)
  4. No.
I would go to the option to have different portals within one installation. The contents are separated by the portal ID, but you can also share content (and also users) over the portals if you want. And afair you can restrict the use of a module to one (or more, but not all, or to all) portals.
I know that there was MS Access support (up to version 2.1.2), but I never heard that DNN was running on (classic) ASP. The first DNN Version (and all it's predecessors, IBuSpy Workshop and IBuySpy Portal) were running on ASP.Net. Therefore excuse my question: Are you real?
