Custom module throwing exceptions when updating settings
Hello,
I noticed a some strange behavior today when updating any(all custom modules) of my module settings.  My module runs just fine, and even updates fine.  But after a do an update I see this in error log about 4 times:
 DotNetNuke.Services.Exceptions.Exceptions - System.Threading.Tasks.TaskCanceledException: A task was canceled. at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Tracing.ITraceWriterExtensions.d__18`1.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Controllers.ApiControllerActionInvoker.d__0.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Tracing.ITraceWriterExtensions.d__18`1.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Controllers.ActionFilterResult.d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.AuthorizationFilterAttribute.d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.AuthorizationFilterAttribute.d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Controllers.ExceptionFilterResult.d__0.MoveNext()
Here is my updatesettings function:
Can anyone help me?  dnn 9.7.2
 public override void UpdateSettings()
            try
                Entities.Modules.ModuleController objModules = new Entities.Modules.ModuleController();
                if (UserInfo.IsSuperUser)
                    objModules.UpdateTabModuleSetting(TabModuleId, "smtpServer", this.tbServer.Text);
                    objModules.UpdateTabModuleSetting(TabModuleId, "smtpServerPort", this.tbPort.Text);
                    objModules.UpdateTabModuleSetting(TabModuleId, "smtpUsername", this.tbUsername.Text);
                    objModules.UpdateTabModuleSetting(TabModuleId, "smtpPassword", this.tbPassword.Text);
                    objModules.UpdateTabModuleSetting(TabModuleId, "emailTo", this.tbEmailTo.Text);
                    objModules.UpdateTabModuleSetting(TabModuleId, "emailFrom", this.tbEmailFrom.Text);
                    objModules.UpdateTabModuleSetting(TabModuleId, "CapthaVisible", this.cbCaptha.Checked.ToString());
                    objModules.UpdateTabModuleSetting(TabModuleId, "Populate", this.cbPopulate.Checked.ToString());
            catch (Exception exc) //Module failed to load
                Exceptions.ProcessModuleLoadException(this, exc);
First, it seems like your code could use a bit more bits of defensive coding, such as trimming the user inputs, and validating their values (even if it was already done client-side).
(Also, I'd always recommend using the DNN API to send emails, and not do that manually in the module. There's a lot of really good code that has been written over the years that you're most likely bypassing and instead writing yourself.)
Anyhow, I don't see anything in your code that would immediately cause the error you pasted, but it could use one more line of code in the `Try` block, as seen below.
<code>// synchronize the module settings<br /> ModuleController.SynchronizeModule(ModuleId);</code>
Hi Will,
Thank you for your great answer and excellant advice - but that wasnt the problem - I added the line just above the updating and tryed below also.
Took me a while to find out where this was comming from - not allot of real good info in that exception.  And it seems to be comming somewhere within dnn code ?  Possibly updating a module interfering with purge module cache scheduler task or something?  It also seems to be intermittent, but happens allot.
Thank you and have a Merry Christmas!
It sounds like you might have found the fix on your own.  If you don't mind me asking, what was the cause/fix?
Hi Will,
No I did not find a solution to this issue.
Just know where it is comming from is all.
Oh, got it...
Well, nothing in your code sample was obviously wrong or something that I might think could cause that specific exception.  Do you happen to know if your instance of DNN has any source code changes?
Are you using any third-party extensions or customizations like TurboScript, that changes how DNN functions?
No it does not - trying to keep that way as far as dnn source code changes.  I am using POLO skin, DNN userImport/export(from forge), and thats about it.  It seems like a pretty generic exception - and like I said it updates my settings and displays them.  I tryed to disable some of the schedular tasks - like purge module cache, purge output cache which run every minute - it seemed to get better , but didnt have time to go any further.  Just cleaning up before our site goes live - lots to do.  It seems sorta like a thread abort exception or something(like when you do a re-direct) - but not real sure.
Well, I still can't see anything wrong in the information you've provided so far.  If it were me, my next step would be to get a clean copy of a web.config with no changes made to it after installing the same version of DNN.  Then, do a compare/diff on the two web.config files to see if there is anything added/missing that might be causing this issue.
