dnnConfirm fires on 2nd click
...well, not always :)
When logged in as an "ordinary" user it works fine, but when I log in with the host account it fires after 1st click (and then it works fine).
In my module there's a radGrid with imagebuttons.
The script is:
    jQuery(function () {
        Sys.Application.add_load(function () {
            jQuery(".confirmingGrid .DeleteButton")
                .each(function () {
                    $(this).dnnConfirm({
                        text: "<%= DotNetNuke.UI.Utilities.ClientAPI.GetSafeJSString(LocalizeString("DeleteItem.Text")) %> '" + $("td:eq(2)", $(this).parents("tr")).text() + "'?",
                        yesText: "<%= DotNetNuke.UI.Utilities.ClientAPI.GetSafeJSString(LocalizeString("Yes.Text")) %>",
                        noText: "<%= DotNetNuke.UI.Utilities.ClientAPI.GetSafeJSString(LocalizeString("No.Text")) %>",
                        title: "<%= DotNetNuke.UI.Utilities.ClientAPI.GetSafeJSString(LocalizeString("Confirm.Text")) %>",
                        dialogClass: "dnnFormPopup",
                        isButton: true
In my codeBehind i have:
   JavaScript.RequestRegistration(CommonJs.DnnPlugins)
   DotNetNuke.Framework.jQuery.RequestDnnPluginsRegistration()
   ClientAPI.RegisterClientReference(Me.Page, ClientAPI.ClientNamespaceReferences.dnn)
Testing on DNN 9.2.
Any ideas?
Kristian Radolović
Quality In Quality Out d.o.o.
Hi Kristian,
I'm not a dev myself but I had a quick chat with Daniel Valadas and his answer was:
"I don't have a great answer without much more time to test, but a couple notes.. DnnGrid is a wrapper around RadGrid that was deprecated many years ago and moved into the Dnn.Web.Deprecated.dll library to make sure people really know about it and should not be used. The good advice here would be to not use it and check if the problem still persists. My best guess is that something may fire up with the RadGrid javascript that intercepts the first click or some such..."
Is this any help?
Tycho, sadly it does not help - i'm not using DnnGrid, i'm using RadGrid itself.
As it works fine when an ordinary user logs in, my suspicion goes to the personaBar or javascript(s) loaded when host/admin user logs in.
Kristian Radolović
It looks like you may be using a deprecated API endpoint to load the required DNN JS.
Update your DNN JS reference from this:
<code>DotNetNuke.Framework.jQuery.RequestDnnPluginsRegistration();</code>
To this:
<code>using DotNetNuke.Framework.JavaScriptLibraries;<br /> JavaScript.RequestRegistration(CommonJs.DnnPlugins);</code>
