URL Control not Registering Correctly in Module Template
Briefly, I'm using the Chris Hammond Template. In the edit view, I can't get the ID of the to register correctly. I keep getting the error.
Get run through
Settings for my solution.
Under solution properties, my output folder is set to ..\web\local.dnn.com\bin\
Along with all my references point to the bin folder in my DNN site C:\web\local.dnn.com\bin\
In Edit HTML
<%@ Register TagPrefix="dnn" TagName="UrlControl" Src="~/controls/UrlControl.ascx" %>
<dnn:UrlControl ID="firstLinkEditorDM" CssClass="form-label push-right" runat="server" ShowFiles="true" ShowNewWindow="false" ShowUrls="true" ShowLog="false" ShowTrack="false" ShowUpLoad="false" />
<asp:TextBox ID="firstLinkTextEditorDM" CssClass="form-control d-block" runat="server" />
Code Behind in my First statement my id always shows a red underline with the error "The name "firstLinkEditorDM" does not exist in the current context."
Same with the   ID firstLinkTextEditorDM
I've checked my refrences and not sure why I'm getting the error
using System;
using System.Drawing;
using System.Net;
using System.Web;
using System.Web.UI;
using DotNetNuke;
using DotNetNuke.Entities.Modules;
using DotNetNuke.Services.Exceptions;
using DotNetNuke.Services.FileSystem;
using Telerik.Web.UI;
 public partial class Edit : AssociationProductListBannerModuleBase
        protected void Page_Load(object sender, EventArgs e)
            try
                if (!Page.IsPostBack)
                    var modules = new ModuleController();
                 // First Link
                    if (Settings.Contains("_firstLinkTextDM"))
                        firstLinkTextEditorDM.Text = Settings["_firstLinkTextDM"].ToString();
                    if (Settings.Contains("_firstUrlControlDM "))
                        firstLinkEditorDM.Url = Settings["_firstUrlControlDM "].ToString();
            catch (Exception exc) //Module failed to load
                Exceptions.ProcessModuleLoadException(this, exc);
