FirstName and LastName being set blank
 24 Subscribed to this forum
Joe
I realize this is not the correct place for this, but I really dont know where to look and hopefully you can point me to the correct location.
DNN has started setting the users.firstname, users.lastname to '' (Blank).  I ran a trace on the DB and here is the code see where @2=N'',@3=N'' is set to blank.
exec sp_executesql N';Exec dbo.UpdateUser @0, @1, @2, @3, @4, @5, @6, @7, @8, @9, @10, @11, @12, @13, @14, @15',N'@0 int,@1 int,@2 nvarchar(4000),@3 nvarchar(4000),@4 int,@5 nvarchar(4000),@6 nvarchar(4000),@7 nvarchar(4000),@8 int,@9 int,@10 int,@11 nvarchar(4000),@12 nvarchar(40),@13 datetime,@14 int,@15 int',@0=13,@1=0,@2=N'',@3=N'',@4=0,@5=Ncorrectemail,@6=Ncorrectemail,@7=N'',@8=0,@9=1,@10=0,@11=N'73.237.35.66',@12=N'268a0392-05de-4eef-b786-baf461f54566',@13='2023-06-01 22:40:54.767',@14=0,@15=-1
I believe this is a result of us setting the user first name and user last name as required.  This is DNN calling this when the user logs into the system.  I dont know where DNN is getting the ''.  The user names are correct in the users table AND the userprofile table.  If I leave the users table blank, DNN will update the userprofile table to blank as well.
Has anyone seen this?  I found this
https://www.dnnsharp.com/...e-being-erased-64846
With the same issues, but NO updates as to what it was.
Any help would be appreciated.
7 Engaged Reader
Have you looked into GitHub for existent errors already logged (https://github.com/dnnsof...nn.Platform/issues)?
This sounds like the DNN instance you're working on may have been modified by someone. Meaning, there are very likely core code changes that are causing this unusual behavior. I'd suggest auditing the database and file system to restore all of the core code back to its original state.
Joe
Posted By Marco Alvarado on 11/23/2023 5:07 PM
Thanks, I did a search and could not find a similar issue.
Did you ever find what was calling dbo.UpdateUser & setting it to ''? I am on 9.6.1 and SP: dbo.UpdateUser keeps setting a single users first/last name to ''.
What other modules are installed?
Lots but most are our own C# code. Is there a way to export the list or get it using SQL?
I just noticed we still have DNNSecurityHotFix1 & "DNN Security HotFix 2017.1".
It sounds like you might need to upgrade before you finish troubleshooting this. 🤔
Either the cache is not working and return "" or something is setting it to "" in the cache only. Table UserProfile always has the correct value.
