DNN HTML Editor Constantly Stripping or Changing My Code
 6 Subscribed to this topic
Page 1 of 3123 > >>
Hey everyone,
I’m running into a frustrating issue with the DNN HTML editor. Every time I add custom HTML, CSS, or JavaScript to a module using the HTML editor, it keeps stripping out parts of my code or modifying it automatically when I go back in to edit.
For example:
Inline styles and script tags get removed or rewritten.
The editor sometimes reorders or reformats the markup.
When I save and reopen, certain tags or attributes vanish completely.
This makes it a pain to work with, especially when building custom layouts or embedding dynamic content.
I’ve already tried:
Switching between “Basic,” “Enhanced,” and “Advanced” modes in the HTML editor.
Checking the HTML editor provider settings (CKEditor).
Turning off “Replace Tokens” and enabling “Raw” mode when possible.
Still, the problem persists.
Has anyone found a reliable fix or workaround for this? Ideally, I’d like to disable all automatic filtering or sanitation so my code stays exactly as I entered it.
Thanks in advance — any insight would be greatly appreciated!
— Joseph
DNN Platformv. 10.01.02 (0)
.Net Framework4.8.0
Server NameNebulaWeb
ChatGPT suggested;
Editor Config field (top section, where you see “AllowedContent”), paste this:
AllowedContent: true,
ExtraAllowedContent: '*(*);*{*}',
AutoParagraph: false,
HtmlEncodeOutput: false,
Entities: false,
FillEmptyBlocks: false,
BeautifyOnSave: false,
StartupMode: 'source'
This may be becuase of the security feature in DNN.  Here is my ChatGTP answer.
Question: In DNN CMS the security fo rthe ediotr strips JS from the input, how can i stop that in DNN10
Answer:
Ha Ha.... I can post it here becuse of security, :-)   Ask the question to chatgpt.
can NOT post that is.
David, pls explain?
As others have noted most likely this is due to the default configurations of CKEditor.
I do encourage you to consider however the risks associated with opening this up, especially if you have multiple levels of users that make content edits as you can expose yourself to risks, especially with JS inclusions.
Mitchel,
If adding CSS to a content section to format text is regarded as a security risk then what is the suggested alternative.
I use classes to format complex tables so they can be viewed on phones.
Regards
Hi Simon,
Tables are usually styled in the CSS of the theme. Or in the module.
Styling in the editor makes it part of the content and therefore inefficient.
If for some reason you can not edit the code of the theme or module, you can always use the portal.css to overwrite other css.
The HTML editor can be set quite specific. For instance to allow classes but not divs or js.
I have been trying to open the CKEditor Provider Settings space on a number of my DNN 10.2.0 sites. The Loading Options popup never goes away and I am unable to make the changes I need to make. Aware that site size may have an impact I have tried this on my smallest site (3 pages) and again unable to open this.
Have there been changes intended to stop any editing of these parameters?
Page 1 of 3123 > >>
