Forum: Administration and Configuration
 40 Subscribed to this forum
Page 1 of 9212345 > >>
Topics
Replies
Rating
Status
Views
Subscribers
Last Post
First time configuring DNN?
Started By  Will Strohl
Is this your first time configuring DNN  Did you just get told to take care of the website and don't know where to even begin  Well, you're in the right place.  Ask your configuration/admin questions in this forum and also feel free to review the documentation for this topic using the link below. [Edited by someone other than Will ...] https://dnndocs.com/content/administrators/ The link above doesn't work.  You may want to look at https://dnndocs.com, but the admin section is decided...
5017 2
Transaction log bloats and fills up causing issues
Started By  Malcolm Bradley
I really hope there's someone who can help me.  I have a DNN 9.10 installation which every few months causes either the site to crash or if noticed early enough will not allow users to login. When attempting to login the following message appears... The transaction log for database 'xxxxxxx.com' is full due to 'LOG_BACKUP'. My host support team reports the database has bloated significantly so they reduce the size of the database and all is well again. I had sugested this https://www...
5 348 1
Set rate limit on password reset
Started By  willem
DNN does not apply rate limiting to incoming requests. The endpoint for requesting a password reset link accepted repeated consecutive requests, with the server returning an HTTP 200 response each time. No blocking, throttling, CAPTCHA, temporary lockout, or HTTP 429 'Too Many Requests' response was observed.  Is there a way to set a rate limit (retry limit) on password reset
198 0
by willem
Messaging Module
Started By  Michael Tobisch
Hi all, I have a very long-living DNN installation (started with 4.9.5), and due to regular updates is now on 9.7.2. I installed the Telerik Identifier Module to prepare for the next step - and found this assembly: DotNetNuke.Modules.Messaging.dll As far as I can see, this belongs to the old Messaging module, which is not in use anymore (it was displaced by a module called 'Message Center', but obviously not uninstalled). I cannot uninstall this leftover from the UI, as it is marke...
3 3126 0
Image processor in DNN 10
Started By  willem
I have the latest version of DNN 10 and the latest version of Open Content. I want to use an image processor to crop, resize, compress images, etc. Which image processor should I use and how can I best implement it  The main thing is that I can use it within Open Content.
9 377 2
by willem
Themes Using Bootstrap 4 vs Bootstrap 3
Started By  tony bonn
Is mixing a site theme using boostrap 4 a risk if mixing with modules still using boostrap 3. i am not sure about backward compatibility in the context of dnn 9.8 (or anywhere else for that matter)
9 3053 2
Cookie consent options for allowing/declining
Started By  Intellicom
Hello, We are using the built-in DNN cookie consent feature in Site Settings > Site Behavior > Privacy, which is working and shows the message with the 'Got it!' button.  I saw on the homepage of the dnnsoftware.com website though that it looks like they may be using the same built-in cookie consent (based on what I see when inspecting the HTML) but they have options to either 'Allow cookies' or to 'Decline'. Is this possible to do with the built-in cookie consent on our DNN sites I am te...
1 180 1
Measures against trace.axd
Started By  Kasi
Recently, there have been numerous attempts to attack DNN websites using a trace.axd exploit. Is there a recommended measure for DNN, or can these be ignored
2 211 2
by Kasi
Service Unavailable
Started By  Forro_54
Hi to all, I have getting this error when trying to update blog user permissions on DNN 10.03.02 with DNN Community Blog V6.7.1 settings page. I had the same issue in the past and had to do a clean install of DNN 10 and DNN Blog 6.7.1 to overcome it. Past attempts to resolve this have been unsucessful . Maybe someone can interpret this error Page Load Exception Trevor  Forrest Ministries Australia  AbsoluteURL /Default.aspx DefaultDataProvider DotNetNuke.Da...
1 176 0
How to delete module message
Started By  sjones
We have a custom login page which is mostly a copy of the default one. However, if a user signs in and they need to accept terms and update their profile. They are first prompted for terms acceptance: And then prompted to update their profile: All good except the message for 'You must accept out terms to continue' which remains after proceeding from the accept terms page to the update profile page.  How can we remove this message This is the code which is largely the same as...
2 189 1
by sjones
RSS Feed Available
