DotNetNuke-7 Module
Hello, I am using DotNetNuke version 7.0. I develop DNN modules on my local computer with Visual Studio. After building a module, I upload it to the server by logging in as a master user and installing an extension (I take the install-file, but I also tried the source-file). This all works very well.  Unfortunately I can't see my server-side code on the server after uploading and installing a module. The file is not displayed when I open Visual Studio on the server. Everything that is executed at the client-side is displayed. However, the code behind it is missing on the server. However, the module works perfectly. So the server-side code must be somewhere. But I can't find it.
How do I access the code behind when I'm on the server?
Thank you.
Sounds like you are deploying the INSTALL package of the module, NOT the SOURCE package. The INSTALL package is typically compiled into a DLL and that DLL will exist in the website's BIN folder.
Also, you may run into some issues if you install both the source and install packages since code lives in both source and compiled versions.
In most cases, you actually don't want to be able to see your source code on the server. In fact, depending on what you're deploying, you absolutely would never want the source code on the server.
The only exception would be if you're deploying non-compiled extensions, but even in this case, I'd suggest compiling the extensions instead. Regardless, keeping the source code organized will not be easy over time. This very scenario probably accounts for half the clients we've on-boarded over the past 2 years.
