Most Extension installs fail on DNN 9.4
I am unable to install some extensions on DNN 9.4. I am getting the following message:
Zip File Upload Failed
An unknown error has occured. Please check your installation zip file and try again.
  • Zip file size is too large, check your IIS settings for max upload file size.
  • Missing resources in the zip file.
  • Invalid files in the package.
  • File extension is not .zip.
  • Check that you are logged in
The following message is being shown in the Admin Logs:
AbsoluteURL:/API/PersonaBar/Extensions/ParsePackage
ExceptionGUID:408947ca-73a8-4c35-b37a-2fc35379acfe
AssemblyVersion:
PortalId:-1
UserId:-1
TabId:-1
RawUrl:
Referrer:
UserAgent:
ExceptionHash:bzFFur7Z3Wwo3q7sDV87ASSNi6g=
Message:The operation was canceled.
StackTrace:
at System.Threading.CancellationToken.ThrowOperationCanceledException() at System.Web.Http.Filters.ActionFilterAttribute.d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.ActionFilterAttribute.d__0.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Controllers.ActionFilterResult.d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.AuthorizationFilterAttribute.d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.AuthorizationFilterAttribute.d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.AuthorizationFilterAttribute.d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.AuthorizationFilterAttribute.d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.AuthorizationFilterAttribute.d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Controllers.ExceptionFilterResult.d__0.MoveNext()
InnerMessage:
InnerStackTrace:
Source:mscorlib
FileName:
FileLineNumber:0
FileColumnNumber:0
Method:
Server Name: W26
The extensions are installing fine on a local installation of DNN 9.4 but they are not installing on my live site running DNN. 9.4.
did you check package size supported?
PS: also make sure, the server is running proper .Net version!
I'm not sure what you mean by this. Where do I check this?
