Portal logo use in module
I have a simple module that pulls contact information into a site from the DB and also includes schema tags. My sites aren't passing Google's Structured Data validation because the tool now requires an image.
How can I load the portal logo into the module? I can't have a static path because the file name of the image will change from site to site.  I use the <dnn:Logo id="SiteLogo" runat="server" /> tag in the skin, but that doesn't work within the module.  Is there a way to get that tag to work in the module?  Or will I need to pull the logo image the same as the other information?
Thank you!
Bobby,
What about
PortalSettings.LogoFile
Thanks for the suggestion Michael. I tried that & it also didn't work, but when added to a standard skin file it does. I assume because I'm trying to use it in an html file loaded by the module - so the tag isn't being converted into a url path. I'll be able to get a custom solution created, but was hoping to find something out of the box to make it easier.
Bobby,
I don't know exactly what you are doing, but I would try to add [Portal:LogoFile] to the HTML file and then use the token replacement feature (DotNetNuke.Services.Tokens.TokenReplace class) before presenting the output.
