Using datepicker in DotNetNuke-7 module
I'm a DNN beginner. I am currently building a module in which I can display statistics. My DotNetNuke Version is 7.0. The statistic is from Chartjs. For this statistic I would like to implement filters. These filters should be datepickers. As UI element I have now included a textbox with `TextMode='Date'`. But currently I have problems to set the default value of this field. The default value should be `01.01`. of the current year.
I have already tried to set the value via C# server side. Unfortunately without success. I also tried to set the value on the client side via JavaScript. Unfortunately also without success.
These are some lines I tried in JavaScript:
document.getElementById(<%= this.DatumVon.AccessKey %>).value = "01.01.2019";
document.getElementById(<%= this.DatumVon.AccessKey %>).innerText = "01.01.2019";
document.getElementById("DatumVon".value = "01.01.2019";
These are some lines I tried in C# in the method "Page_Load" (server side):
this.DatumVon.Text = "01.01.2019";
I expected the value of the TextBox to be `01.01.2019`. However, it currently only contains `dd.mmm.yyyy`. How can I change this?
Thank you.
As I answered here (https://stackoverflow.com...e/56645025#56645025) already - there seems to be something wrong with the localization. Please refer to the jQuery UI datepicker documentation (api.jqueryui.com/datepicker/ - the "Localization" section), this should give you the answer.
I already tried the jQuery datepicker. But here is the problem that DNN 7.x is not compatible with it. It doesn't work with jQuery datepicker. Therefore I decided for a textbox with TextMode='Date'.
As I posted in my comment on the Stackoverflow page, DNN is using the jQueryUI datepicker. It works fine for me.
To get a German date format, you have to include the file "jquery.ui.datepicker-de.js" somehow - https://github.com/jquery...er/cdn/ui/1.8.8/i18n
