Language selector - Text just language not region
 25 Subscribed to this forum
When displaying just text in the language selector is there anyway to display just the language name not the region
ie: Show 'English' instead of 'English (US)'.
There used to be a module Apollo Language Selector that could do this but that does not seem available anymore
Thanks in advance for any help given
Tony
Hi Tony,
Here's a list of tokens you can use:
Token
Description
Core Token replace
You can use all the DNN core tokens in these templates
[CULTURE:DISPLAYNAME]
Gets the culture name in the format " ()" in the language of the localized version of .NET Framework.
[CULTURE:ENGLISHNAME]
Gets the culture name in the format " ()" in English.
[CULTURE:LCID]
Gets the culture identifier for the current CultureInfo
[CULTURE:NAME]
Gets the culture name in the format "-".
[CULTURE:NATIVENAME]
Gets the culture name, consisting of the language, the country/region, and the optional script, that the culture is set to display.
[CULTURE:TWOLETTERISOCODE]
Gets the ISO 639-2 three-letter code for the language of the current CultureInfo
[CULTURE:THREELETTERISOCODE]
Gets the ISO 639-1 two-letter code for the language of the current CultureInfo
[URL]
This will generate the correct URL for the current page in a specific culture
[FLAGSRC]
The name of a flag image (.gif only) for a specific culture, in the format "-.gif".
[SELECTED]
Returns “True” if a specific culture is the current culture.
[LABEL]
Inserts the Label text from the resource file.
[I]
Returns the directory that holds the core country flag images (/images/Flags)
[P]
Returns the portal directory
[S]
Returns the directory of the current skin
[G]
Returns the global (host) skin folder
Examples:
Example Code
Description
<dnn:LANGUAGE runat="server" ID="dnnLANGUAGE" ShowMenu="False" ShowLinks="True" />
Default configuration in default DotNetNuke skin.
<dnn:LANGUAGE runat="server" ID="dnnLANGUAGE" ShowLinks="False" ShowMenu="True" />
Displays only dropdownlist
<dnn:LANGUAGE runat="server" ID="dnnLANGUAGE" ShowLinks="False" ShowMenu="True" CommonFooterTemplate=' <img src="&#91;I&#93;&#91;FLAGSRC&#93;" alt="&#91;CULTURE:NATIVENAME&#93;" border="0" />' />
Displays dropdownlist and flag of currently selected language
<dnn:LANGUAGE runat="server" ID="dnnLANGUAGE" ShowLinks="True" ShowMenu="False" ItemTemplate='<a href="&#91;URL&#93;" class="Language" title="&#91;CULTURE:NATIVENAME&#93;"><span class="Language&#91;SELECTED&#93;">&#91;CULTURE:NAME&#93;</span></a>'/>
Displays text links for languages. Selected language has different Classname
there is also an extended language selector skin object from interzoic, but i didn't test compatibility with DNN 8 or 9 yet
https://www.interzoic.com/languageskinobject
Hi Timo,
Unfortunatly none of those tokens work they way I want. They show the region like 'English (Canada)'
Tony
Hi Sebasation,
I had tried registering on that site yesterday to download the object, unfortunatly the registration does not seem to work. I have contacted them to ask for help
I could create my own object if I knew how to get the different urls of a page for each language...any pointers ?
Regards
Tony
Tony,
if you want to create the Language Selector SKO yourself, you should start with the skin object inside DNN Platform, rename and extend it according th your needs.
Posted By Tony Stallan on 14 Nov 2019 09:31 AM
Hi Timo,
Tony
Hmm, right.
I think that needs to be added to the core then.
A quick and dirty solution would be:
< span class="[CULTURE:TWOLETTERISOCODE]">< /span>
CSS:
.EN:after{
content:English;
Hi Timo,
Great idea, I will give that a go
Tony
Many thanks Timo
Worked like a charm.
Tony
