Search Error in other languages
 25 Subscribed to this forum
Leo
Hello,
I have a question for Search.
When I type some text, for example , type "Support" in Search in EN then pop up result with text below:
"Our Technical Support Team is always ready to assist you and to answer any technical questions relat...
Support...nical Support Team................. "
It means English is fine for Search.
However, in FR,ES,DE,KR,CH,JP,PT it does not showed up with this message "no result  found",검색 결과가 없습니다.(korean) Aucun résultat trouvé.(FR)". I typed same text such as "Support(EN)."
It means that "support(FR) Soporte(ES) 지원(KOREAN))"
I hopely get the solution for the error.
Thank you.
are you using DNN Content Localization? Did you provide the translated text on your site?
Did you install language packs for the other languages (should translate login, register etc. on your skin)?
Leo
Hello Sebastian Leupold,
Yes, we have been using DNN Content Localization. We had translated text all languages and installed languages pack for the other languages(login, register etc.) Nevertheless, the search in other languages works randomly (sometimes results and sometimes not) .
