DDR menu configuration
I am setting up a DDR menu in 9.2 and I am only able to display either the entire menu (all visible pages) or the children of the current page. I have used Node selection expression = "RootChildren" or "CurrentChildren" but all other expressions I have tried do not work. I am trying to display all pages that are on the same level as the current page, so display all children of the current page's parent only.
You can use {root} options to have a try. With regard to how to use it, please check instruction here:
https://www.dnnsoftware.c...menu-reference-guide
Hope it helps.
Best regards,
Linda
Website: https://www.dnngo.net
E-mail account: [email protected]
Skype: dnngo-linda
You may find this useful: https://www.dnnsoftware.c...menu-reference-guide
This may also be somewhere in the new DNNDocs website, but I didn't find it quickly.
This may be what you are looking for: NodeSelector="+0"  (I stole this from a website that, I think, does what you want.)
I find it convenient to drop the module version of the DDR Menu onto a page for experimentation.  For simplicity use the ULTokens menu and experiment with the NodeSelector parameter
Posted By Catherine Foss on 01 Jul 2019 04:29 PM
We created a (free) DDR demo skin with loads of examples.
I think you need this to show the current page's siblings:
<code>NodeSelector="-1,0,0"</code>
<code>&lt;dnn:menu menustyle=&quot;Menus/02.01-DDR-XSLT-UL-Classes&quot; nodeselector=&quot;-1,0,0&quot; &#114;&#117;nat=&quot;server&quot;&gt;</dnn:menu></code>
Demo: https://demo.40fingers.ne...DR-Menu-NodeSelector
I just checked on a test system. Both Timo's and my suggestions work. I actually like Timo's version as it is easy to read and makes sense.
The node selector is {root},{skip},{depth}. So, in this case
-1 sets the root to the parent of the current page
0 says don't skip
0 says children of the root page
And, actually, my solution works only if the current page is a child of a top level page, so it's wrong for lower level pages!
FYI - The DDRMenu documentation has since been moved to and is maintained on the DNNDocs website. :)
The link is 404. Where are the current docs?
Are the pages you want to display also hidden from the menu?  Meaning, when you created the page(s) - is the "display in menu" switch on?
