Error setting up user control code-behind
I'm trying to incorporate this non-DNN dev page (http://hstoneart.com/Port...stoneArtGallery.aspx ) into a new page template file. The new file is based on the Xcillion Inner.ascx; the problem is that I can't get the code-behind to work. When I load a page using the new template, I get the error "Could Not Load Theme: /Portals/_default/skins/hstoneartskin/hsa_inr_modal.ascx, Error: E:\web\drawingwork\htdocs\Portals\_default\skins\hstoneartskin\HSA_inr_modal.ascx.vb(11): error ASPNET: Make sure that the class defined in this code file matches the 'inherits' attribute, and that it extends the correct base class (e.g. Page or UserControl)".
The pages appear in Visual Studio Solution Explorer as parent and child. I've Googled and tried different combinations of "Class Name" and "Inherits" values, I've added a Namespace, and I've cleared the VWDWebCache folder and rebuilt the web. I know I must be missing something basic. Can anyone help? Thanks.
Control declaration:
<%@ Control Language="vb" AutoEventWireup="false" Explicit="True" CodeFile="HSA_inr_modal.ascx.vb"  Inherits="hstoneArtGallery" %>
Beginning of code behind:
Imports System
Imports System.IO
Imports System.IO.Directory
Imports System.Web
Imports System.Data
Partial Class hstoneArtGallery
    Inherits System.Web.UI.Page
I think the editor deleted some of the code you posted?
If you try to write a module, you should inherit the partial class from PortalModuleBase.
Actually, I left it out. I figured that the code inside the Class tags would be of little interest. Here's the code:
Imports System
Imports System.IO
Imports System.Web
Imports System.Data
Partial Class HstoneArtGallery
    Function ImportTextFile(ByVal strTextFileName As String) As String
        Dim strTextFilePath As String = Path.GetDirectoryName(Server.MapPath(Me.ToString)) & "\notes\"
        Dim strReturnedText As String
        Using sr As New StreamReader(strTextFilePath & strTextFileName)
            strReturnedText = sr.ReadToEnd()
        End Using
        Return strReturnedText
    End Function
    Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
        Dim strPathToImagesFolder As String = Path.GetDirectoryName(Server.MapPath(Me.ToString)) & "\images\"       'declares path to images folder
        Dim strFileSystemEntryImage As String
        Dim arrGetFiles() As String = Directory.GetFiles(strPathToImagesFolder)     'sets up array of files in image folder
        Dim arrFileNames() As String
        Dim strFileName As String
        Dim strCleanedFilename As String
        Dim arrAltTitleTag As Array
        Dim strAltTitleTag As String
        Dim intNameCounter As Integer
        Dim imgAltTag As String
        intNameCounter = 0
        Dim imgID As String
        Dim strThumbnailsMaker As New StringBuilder
        strThumbnailsMaker.Append("
        thumbnailsPanel.Controls.Add(New LiteralControl(strThumbnailsMaker.ToString))
    End Sub
    Private Function WriteFileInfo(ByVal strFilenameInfo As String) As String
        Dim arrSplitOnExclamation() As String
        Dim strToReturn As New StringBuilder
        If InStr(strFilenameInfo, "!") > 0 Then
            strFilenameInfo = strFilenameInfo.Replace("_", " ")
            arrSplitOnExclamation = Split(strFilenameInfo, "!")
            Dim arrLastValue() As String
            arrLastValue = Split(arrSplitOnExclamation(5), ".")
            strToReturn.Append("")
            strToReturn.Append(arrSplitOnExclamation(1))
            strToReturn.Append(arrSplitOnExclamation(2))
            strToReturn.Append(", ")
            strToReturn.Append(arrSplitOnExclamation(3))
            arrSplitOnExclamation(4) = Replace(arrSplitOnExclamation(4), "in", """")
            strToReturn.Append(arrSplitOnExclamation(4))
            strToReturn.Append(arrLastValue(0))
        Else
            strToReturn.Append(" ")
        End If
        Return strToReturn.ToString
    End Function
End Class
Here's the Control statement at the top of the ascx file:
<%@ Control Language="vb" AutoEventWireup="false" Explicit="True" CodeFile="HSA_inr_modal.ascx.vb" Inherits="HstoneArtGallery" %>
I changed:
to
    Inherits PortalModuleBase
and the error remained. I probably didn't do that exactly right.
I'm not trying to write a module, just a page template.
Posted By Britomart on 10 Aug 2022 05:37 PM
I changed:
In that case I would recommend to have a look at one of the multi-purpose modules like OpenContent or 2sxc. It should be easy to achieve your goal with one of these if you're familiar with HTML and JavaScript.
I couldn't get OpenContent or 2sxc to install; they both went to 95% and stalled. I contacted the host to verify that I had space and checked the web.config and DNN setting to verify that the files weren't too big, still didn't work. I've been trying to figure it out with no luck. I've tried simplified layouts and inline code instead of code-behind. Any attempt to run VB code on any of the test pages generates error "Could Not Load Theme: /Portals/_default/skins/hstoneartskin/hsa_gallerygen.ascx, Error: Unable to cast object of type 'ASP.portals__default_skins_hstoneartskin_hsa_gallerygen_ascx' to type 'DotNetNuke.UI.Skins.Skin'. I've been trying to track that one down without much luck. I have no idea what "Unable to cast object of type" means, and I could find few references on line.
I'm running DNN 9.10.02 in a clean install with a new host.
Here's the admin log entry:
AbsoluteURL:/Default.aspx
ExceptionGUID:0fa9c969-5832-4cd8-8b15-fb50b0397802
AssemblyVersion:
PortalId:-1
UserId:-1
TabId:-1
RawUrl:
Referrer:
UserAgent:
ExceptionHash:5ZGVzUuVvCZIzAD/onENhymz260=
Message:Unhandled error loading page.
StackTrace:
InnerMessage:Unable to cast object of type 'ASP.portals__default_skins_hstoneartskin_hsa_gallerygen_ascx' to type 'DotNetNuke.UI.Skins.Skin'.
InnerStackTrace:
at DotNetNuke.UI.Skins.Skin.LoadSkin(PageBase page, String skinPath)
Source:
FileName:
FileLineNumber:0
FileColumnNumber:0
Method:
Server Name: web809
What do I do next? Thanks.
