Remove jQuery ClientScript programmatically
<code>Hello,
in a particular template (skin) I don't want jQuery library nor jQueryUI,
so I would like to remove the client libraries injected by </code>DNN.
I've read that is possible configure different version of jQuery but I would like to remove them programmatically at the Page_Load of the skin.
Is there some sort of function like <code>Page.ClientScript.RegisterClientScriptInclude to unregister client library?
For example Page.ClientScript.UnregisterClientScriptInclude(...)?
thanks in adavance
Luca</code>
Luca, you can disable "popups" (SETTINGS > Site Settings > Site Behavior > More > "Enable Popups") to keep DNN from injecting jQuery . Also, if you are using the SEARCH theme object, it will cause jQuery to be loaded.
Oh, and you can also use the DNNJSEXCLUDE theme object if you don't want to, or can't, disable popups.
In addition to David's excellent advice, the StyleHelper theme object by 40Fingers is a great way to fine-tune all kinds of things on your DNN site, including what scripts do and don't get loaded.  But, it's important to still follow the previous advice.  This is just a powerful tool to help you do that and more.
