Where is the Register form?
Happy Monday!
DNN 9.12.
I am in Register.ascx where the User Registration form is being invoked and I need to tweak the Asp/HTML but, I simply can not find where this HTML is being generated.
<dnn:DnnFormEditor id="userForm" runat="Server" FormMode="Short" EncryptIds="True" />
Likewise, there are other DNN modules that follow the same syntax that I'd like to tweak the HTML a bit and can't find them...
Thank you!
You should realize that when you edit these files, they will get overwritten on every DNN update
Normally the HTML is generated in the accompanying C# code behind file which is only in the Source version of DNN. Not in the install package as these are compiled into a DLL.
Maybe copy it and create my own version so it won't get overridden on update? yes, other things "could" happen but I'm not planning ongoing crazy with changes. We're senior devs, I'm not particularily scared to create our own versions of certain modules... :-)
How would I go about getting the source files on an existing project?
Thank you!
Yeah, it sounds like you may want to create your own registration module. The way most of us do this is by either finding and starting with an existing open-source one or... Most commonly, create a module and then pull in copies of the registration code from DNN itself.  Then, begin making the necessary tweaks you're interested in having.
The latter approach is what I'd recommend.  This way, you're not moving forward totally on your own, regarding security.  Meaning, that you keep the code matching what's in the core of DNN itself as much as you can. Then, as newer versions of DNN become available, you can merge in any updates you see, so that you can continue to take advantage of the updates coming in various DNN releases.
However, there's still another option that I sometimes employ.  You can use a third-party module like Live Forms from Mandeeps to not only create a working custom registration/login form, but it can also execute other code you wish to have run.
