After upgrading to 9.11 Persona Bar has gone
 5 Subscribed to this topic
I have upgraded from dnn 9.1 to 9.11 after that the persona bar lost anyone have an idea how to sort it out, the even log also showing blank in database
3ART TechnologiesRegards,
3ART Technologies Expert
3ART Technologies
Experts in Analysis, Design & Development for DNN and SharePoint Solution
https://www.3art.tech/
Maybe a skin issue - please try to use the default skin, if that works you should inspect the problems with the skin, could be some JS  or CSS conflict.
If not:
Did you upgrade directly, or did you follow the DNN Platform Suggested Upgrade Path? From 9.1 you should first upgrade to 9.3.2, then to 9.10.2 and then to 9.11.
Also double-check the DNN Platform Requirements - the ones for 9.4. should still be valid for 9.11.
You should also upgrade any extension you use, if there is an upgrade available.
And don't forget to unblock the ZIP files.
I already applied the default skin but still the same issue arrived.
3ART Technologies
I did it directly from 9.1 to 9.11, the local environment is working fine and the upgrade has done perfectly on it, but when I made the upgrade with live site the live site has damaged
3ART Technologies
I am taking a backup and delete all the file and upload the local version may be it will work
3ART Technologies
Posted By 3ART Technologies Company on 1/13/2023 11:23 AM
I think this could be the problem. You should restore a backup and upgrade step by step.
Also, try this if it happens again:
  1. Using the file manager or FTP (depending on access), navigate to the following folder path:  /DesktopModules/Admin/Dnn.PersonaBar/Resources/.
  2. You should most likely see a single .resources file.  Delete it.  (Or save a renamed backup version of the file, if you want.)
  3. (Optional) Clear any server-level cache using your CDN/WAF, as necessary.
  4. Reload the website, using a hard refresh.
  5. The resources file should be regenerated and the persona bar should load again.
I am facing the same issue did you find any solution to the problem
Posted By Harsh on 4/14/2023 11:44 AM
Have you tried my most recent response yet?  Also, I replied to your other post.
Just upgraded also. 9.10.6 - 9.11.0 and persona bar is gone. Suggested fix did not work.
