The call is ambiguous ... Custom Authentication Module
You are not authorized to post a reply.
    I've got a custom Authentication module put together for two of our partner sites
    Error    CS0121    The call is ambiguous between the following methods or properties: 'Microsoft.Extensions.DependencyInjection.ServiceProviderServiceExtensions.GetRequiredService<T>(System.IServiceProvider)' and 'Microsoft.Extensions.DependencyInjection.ServiceProviderServiceExtensions.GetRequiredService<T>(System.IServiceProvider)'    Smithbucklin.Modules.AuthenticationRhythm    D:\Dev\smithbucklin.DNNAuth\source-code\Modules\Authentication_Partner\Login.ascx.cs
    that's preventing my module from building.
    I know it's tied to a library that just isn't right and was looking for where to hunt to resolve this issue.
    It's happeninng here in my base code which is part of DNN base code.
            private static readonly ILog Logger = LoggerSource.Instance.GetLogger(typeof(Login));
            private readonly INavigationManager _navigationManager;
            public Login()
                this._navigationManager = this.DependencyProvider.GetRequiredService<INavigationManager>();
      Did you name your authentication provider "DNN"? If yes, change it to anything else.
        thanks you sir,
        appreciate it
          Posted By Joshua Rose on 3/26/2024 6:13 AM
          thanks you sir,
          appreciate it
          Always my pleasure... Have a great day!  :)
            Posted By Will Strohl on 3/25/2024 4:24 PM
            Haha - great catch there Mr. Strohl!
