9.11.2 CKEditor Upload Issue
Page 2 of 2 << < 12
Hi Washer ,
Could you please add more details that you resolved? which files, which code need to change..? please
This change done in version 9.11.1 introduced the issue:
https://github.com/dnnsof...form/pull/5416/files
Basically, the drag and drop into CKEditor needed the JSON but the upload dialogs still needed the javascript that was removed to function correctly.
The changes I made were to: DNN Platform/Providers/HtmlEditorProviders/DNNConnect.CKE/Browser/Browser.aspx.cs
The FileUpload and ImageUpload command are used by the two upload dialogs but ImageUpload command is used by the drag and drop as well.  When you drag and drop "&responseType=json" gets added the the request so you can check that to see if that exists to provide the JSON instead of the javascript.
I opened a ticket at: https://github.com/dnnsof...Platform/issues/5645 which as additional information.
Hi! Thanks for creating the issue.
I submitted a PR for it today: https://github.com/dnnsof...n.Platform/pull/5656
Like you said, I used the responseType querystring parameter to determine the kind of response to return.
Greetz,
Stefan
Page 2 of 2 << < 12
