Administering Locked Out Users and dealing with Caching Timeouts
JB
I administer a site that has around 40k users.  Many users forget their passwords, as they only log in around 3 time per year, and end up locking themselves out due to incorrect password attempts.  They will immediately call to have their passwords reset/unlocked.  However, it will take a while (many minutes) for the user page (on the admin side) to show that the user is locked out.  During that time our admins cannot unlock the user as it does not appear as an option on the admin menu.
Upon digging into the code for getting the Users from the ASP.NET membership provider, it appears there is caching mechanism in the "GetUserById" method on the UserController class.  Is there a way to disable the User Caching and have it always look up the full user via the MembershipProvider?
Full Disclosure:
We are running DNN 9.2.2, however, the code of UserController.cs appears to be functionally the same between new versions and 9.2.2.
Thanks,
~Joe
Joe,
I don't think that there is a setting to turn off caching at this point, but what you can do (as a host user, or when you have access to the web server) is clearing the cache (Settings >> Server, button top right) or restarting/recycling the application pool.
there is no option to disable caching selectively for single objects.
You may only switch to a lower caching level in DNN performance settings, which will reduce caching duration. Don't set caching to None - or your site will become REALLY slow.
