CKEditor Custom Headings
How can you set and style the custom heading in the DNN CKEditor? I mean the dropdown with H1, H2, H3 etc...
Can you set a custom js of css? In the editor options screen, in a config file or in the database?
Where can I find some documentation?
Assuming you are working with the default CK editor, the documentation is on https://ckeditor.com/docs...v_howtos_styles.html
Having said that, if you are looking for a way to change the styles, I would do so in the theme css. The HTML that is injected by the CK editor (for instance, if you select H2), would be untouched.
If you are looking for a way to offer an interface to customers that results in a certain style, I would not add a style like Hero caption to the CK editor styles dropdown but use OpenContent or 2SXC. That also prevents unwanted behaviour if a customer uses backspace one time too many.
Thanx!
