DnnImageHandler General Exception Error
DnnImageHandler doesn't work since I moved my website from my local server to a host. I have no Idea How to fix it. The Error occurs whenever DnnImageHandler calls a user's profile image or any other profile property of image type. No user images are shown. DnnImageHandler recurring Error:
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.8.4075.0
DNN 9.4.1
AbsoluteURL:/DnnImageHandler.ashx
ExceptionGUID:d741bc90-73c2-4a85-af1c-d0f2e21547d4
AssemblyVersion:
ExceptionHash:7kgL5R6baI4X2Yh8vqcikOx2+Bs=
Message:Unhandled Error:
StackTrace:
InnerMessage:Parameter is not valid.
InnerStackTrace:
   at System.Drawing.Image.FromStream(Stream stream, Boolean useEmbeddedColorManagement, Boolean validateImageData)
   at DotNetNuke.Services.GeneratedImage.ImageHandlerInternal.GetImageThroughTransforms(Byte[] buffer)
   at DotNetNuke.Services.GeneratedImage.ImageHandlerInternal.HandleImageRequest(HttpContextBase context, Func`2 imageGenCallback, String uniqueIdStringSeed)
   at DotNetNuke.Services.GeneratedImage.ImageHandler.ProcessRequest(HttpContextBase context)
   at DotNetNuke.Services.GeneratedImage.ImageHandler.ProcessRequest(HttpContext context)
   at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
Did you check your web.config file if the image handler is added in the system.webServer/handlers section?
[add name="DnnImageHandler"
    path="DnnImageHandler.ashx"
    verb="*"
    type="DotNetNuke.Services.GeneratedImage.DnnImageHandler, DotNetNuke"
    preCondition="integratedMode" /]
(replace [ by < and ] by >)
Yes, I have the following lines in Web.config file:
[add key="DnnImageHandler" value="EnableServerCache=false;" /]
[add name="DnnImageHandler" path="DnnImageHandler.ashx" verb="*" type="DotNetNuke.Services.GeneratedImage.DnnImageHandler, DotNetNuke" preCondition="integratedMode" /]
Problem solved. I contacted the server administrator. Apparently "Enable 32-bit applications" was enabled in the IIS configuration. Disabling it solved the issue.
Great - thanks for sharing!
