Email not sending
I am looking a two servers. Both configured the same, as far as I can see.
Server One: DNN 9.10.2
ServerTwo: DNN 9.13.2
Server One has no problems.
Server Two fails to send test email:
AbsoluteURL:/API/PersonaBar/ServerSettingsSmtpHost/SendTestEmail
ExceptionGUID:468312ed-f01f-4d85-a3d7-f60bf04c9242
AssemblyVersion:
PortalId:-1
UserId:-1
TabId:-1
RawUrl:
Referrer:
UserAgent:
ExceptionHash:UPlHF73t/GGpNtFq7LermfBUt9Y=
Message:Unable to read data from the transport connection: net_io_connectionclosed.
StackTrace:
   at System.Net.Mail.SmtpReplyReaderFactory.ProcessRead(Byte[] buffer, Int32 offset, Int32 read, Boolean readLine)
   at System.Net.Mail.SmtpReplyReaderFactory.ReadLines(SmtpReplyReader caller, Boolean oneLine)
   at System.Net.Mail.SmtpReplyReaderFactory.ReadLine(SmtpReplyReader caller)
   at System.Net.Mail.CheckCommand.Send(SmtpConnection conn, String& response)
   at System.Net.Mail.MailCommand.Send(SmtpConnection conn, Byte[] command, MailAddress from, Boolean allowUnicode)
   at System.Net.Mail.SmtpTransport.SendMail(MailAddress sender, MailAddressCollection recipients, String deliveryNotify, Boolean allowUnicode, SmtpFailedRecipientException& exception)
   at System.Net.Mail.SmtpClient.Send(MailMessage message)
Using a Powershell script I can send email, from Server Two, using the same SMTP server and credentials.
Any suggestions appreciated.
Regards,
Declan Ward
5 Engaged Reader
I think you have to be more specific here, whether it is a SMTP server in the MS365 cloud. Try to checkout the following issue on github:
https://github.com/dnnsof...Platform/issues/5870
Maybe this is your problem?
Regards, Wolfgang
To be more specific, OAuth is not involved. This is to an SMTP server at blacknight.com. Basic authentication using a username and password.
Outlook can send and receive on the same account and, as I said above, a Powershell script can also send mail to the SMTP server from the problematic server, Server Two.
Setting SMTP server to 127.0.0.1 , anonymous authentication and running a local SMTP server (IIS6) also fails to send a test email with the same error:
Interesting; when I switched to SMTP Server Mode > Global and entered the same server address and credentials it all started working as it should. Using Global is not an issue for me as I only run one site per DNN instance.
So. it was only an issue when using a portal-specific setting?  This sounds like a bug.  What if you switched back to the portal setting? Does it still not work correctly?
I got same error and this thread came up near top of search results.
I was using the Global smtp service. I am able to send test messages from Server>Server Settings>Smtp but not from web based forms
I switched to a local smtp service, domain matching email account and it worked. No idea why.
Do you know how the "web based forms" are sending emails?  Is it using DNN's settings?  If yes, do you know if it's using the newer API endpoints in DNN?
