Error 500
I upgraded my dnn from 9.0.0 to 9.1.1 and an error 500 occur upon running the project. I appreciate any help.
Cris,
any more information about the error 500? This could be a lot of things...
I copied the files of dnn 9.1.1 onto my old 9.0.0 version. The site was offline when I upgraded it. I turned it online, then I opened the website. An error 500 came out.
the website last location is http://www.tulbek.com/Ins...l/UpgradeWizard.aspx
I can see http://www.tulbek.com/
The url with Install/UpgradeWizard.aspx probably fails as that address doesn't exist once the upgrade is complete. The installer deletes much of the Install directory for security reasons.
Can you login to the site? If so, does the 9.1.1 version seem to have installed?
No, I can't login to the site, because upon opening the website the error 500 pops out. The file, Install/UpgradeWizard.aspx still exist.
Interesting, I can browse to http://www.tulbek.com/ and see the home page. And, clicking the login link opens the login popup. You may have something cached in your browser. Try clearing that and trying again. Or try from a different computer.
The version you opened is the good version 9.0.0. I will change it to version 9.1.1 and you get an error 500. You can try it again. This action is immediately after the dnn 9.1.1 is copied onto the old version 9.0.0
