Import/export scheduler fails
I've been having an issue with the scheduler on Import/Export templates.
Basically I want to import a full website in DNN 9.10.2 from a template.
The scheduler fails, gives the message below and the next items in the queue are not processed. The current item that is under execution hangs.
Any ideas?
01/19/2022 16:00:02
Scheduler Exception
AbsoluteURL DefaultDataProvider DotNetNuke.Data.SqlDataProvider DotNetNuke
AbsoluteURL:
ExceptionGUID:5b742f4e-adb5-4473-8b91-29d6943a0f35
AssemblyVersion:
PortalId:-1
UserId:-1
TabId:-1
RawUrl:
Referrer:
UserAgent:
ExceptionHash:aMDzG972z+K/vI4QFlHhZDonswk=
Message:End of Central Directory record could not be found.
StackTrace:
   at System.IO.Compression.ZipArchive.ReadEndOfCentralDirectory()
   at System.IO.Compression.ZipArchive.Init(Stream stream, ZipArchiveMode mode, Boolean leaveOpen)
   at System.IO.Compression.ZipFile.Open(String archiveFileName, ZipArchiveMode mode, Encoding entryNameEncoding)
   at Dnn.ExportImport.Components.Common.CompressionUtil.<>c__DisplayClass7_0.b__0()
   at DotNetNuke.Common.Utilities.Internal.RetryableAction.TryIt()
   at Dnn.ExportImport.Components.Common.CompressionUtil.OpenCreate(String archiveFileName)
   at Dnn.ExportImport.Components.Common.CompressionUtil.UnZipArchiveExcept(String archivePath, String extractFolder, Boolean overwrite, IEnumerable`1 exceptionList, Boolean deleteFromSoure)
   at Dnn.ExportImport.Components.Services.ThemesExportService.ImportData(ExportImportJob importJob, ImportDto importDto)
   at Dnn.ExportImport.Components.Engines.ExportImportEngine.Import(ExportImportJob importJob, ExportImportResult result, ScheduleHistoryItem scheduleHistoryItem)
   at Dnn.ExportImport.Components.Scheduler.ExportImportScheduler.DoWork()
InnerMessage:
InnerStackTrace:
Source:System.IO.Compression
FileName:
FileLineNumber:0
FileColumnNumber:0
Method:
Server Name: RD0003FFDBEA81
01/19/2022 16:00:02
Scheduler Event Failure
THREAD ID 19 TYPE Dnn.ExportImport.Components.Scheduler.ExportImportSchedu
THREAD ID:19
TYPE:Dnn.ExportImport.Components.Scheduler.ExportImportScheduler, DotNetNuke.SiteExportImport
EXCEPTION:End of Central Directory record could not be found.
RESCHEDULED FOR:1/19/2022 4:01:31 PM
SOURCE:STARTED_FROM_SCHEDULE_CHANGE
ACTIVE THREADS:0
FREE THREADS:1
READER TIMEOUTS:0
WRITER TIMEOUTS:0
IN PROGRESS:0
IN QUEUE:10
