Is there a way to duplicate a page and all it's subpages?
Page 2 of 2 << < 12
I recall seeing something about how to handle "collisions" during the import process. YOu'll probably want to look at that.
Thanks - I tried another Import with the "Overwrite Collisions" unchecked. But I still don't see a duplicate set of pages. Any other ideas?
Thank you again
I would assume that overwrite means to replace existing when there is a collision.
You could rename the existing pages and do the import.
Has this evolved in any way over the past 4 years? I find myself in the same situation as Tom and am looking for a way to export a page with a ton of subpages. I'd like to import these pages in the same portal. The only way I see still, is to export the website, with only the pages and content option selected. But when I import this, The page which I exported (and which I renamed) gets overwritten again... and thats not what I want; I'd just like to let them to be added in the portal. There are going to be 6 pages with almost the exact same subpages; only the level 1 page has a different name.
That's an interesting use case.  I don't expect for DNN to add this as a feature anytime soon, unless someone passionate enough does that work and submits a pull request.  However, this sounds like something that someone could build.  It would just need to be a module that's specific to this use case.  The cool thing is that much of the required development work is already inside of the DNN API itself.  Everything else would be to achieve the exact export and import use case(s) you're trying to resolve.
The alternative is to use the site export and import feature, but that's overkill for this and was never meant for a smaller use case (as far as I know).
Well, the site export and import feature would work for me... if my exported page wouldn't be overwritten by the import. Because that's currently the case. But maybe I'm doing it wrong or am I overlooking something.
I am not sure which method for export/import you are using (XML vs JSON), but there is a way (though it can be a bit tedious) to manually rename your pages (within the exported files) to something generic for repeat use.
I would suggest to:
  1. Create the export
  2. Move the original pages to a different parent page (and threat them as the copy)
  3. Import the pages
Great idea Timo!
Yep, that would currently be the best way, thanks Timo.
Page 2 of 2 << < 12
